Results 1 to 6 of 6
Thread: Cat converter
    Oct 2017
    Snellville, GA
    Cat converter
    Hey fellas, one of my cats went bad and was wondering should I replace with stock ones or go hi-flow, thanks in advance.
    2012 300 SRT8 exhaust, intake, tuned, 180 thermostat, oil catch can
    2011 M37s 22's, BC coil overs, exhaust, intake, other small stuff
    2006 Land Rover (Wife's Ride) 22's
    2012 Camaro LS (wife's Ride) 22's, exhaust, intake, stereo upgrade
    2012 Hyundai Veloster (Daughter's Ride)
    2004 Impala SS Supercharged (Sold)
    2004 Escalade (Wrecked) 22's DVD's
    1999 Dodge Durango (Sold)
    1996 Accord heavy Modded (Traded)
    1995 Impala SS heavy Modded (Sold) Gone but not forgotten
    Aug 2012
    iowa
    Unless you can find a set of factory’s cheap you might as well look at some high flows. Although it may require a slight tuning change. Not sure though
    Oct 2017
    Snellville, GA
    I have a t1000 tuner, I should be able to use that right?
    Mar 2008
    UT
    FWIW the high flows I tried flowed less then the OEM cats. Buyer beware!
    Calgary, Alberta
    The OEM catalytic convertors are extremely difficult to beat flow-wise. Your engine would have to be pretty darn healthy before the OEM CATs were an issue. Expect to pay significantly more for CATs that actually out-flow the OEM units. CATs, of any type, do not require any sort of tuning
    Oct 2017
    Snellville, GA
    Thanks for all of the good info on the cats, I will be going with factory ones. Again, this is the place to be.
