Results 1 to 8 of 8
    Jun 2013
    Time for ANOTHER set of Tie rods.... What do you have luck with?
    I'm on my 3rd set of moogs. I miss EVERY pothole on the road WHEN I drive my car. Usually just to work and back which is a very familiar path but seems I can't get more than 10k out of em. I seen the Mevotech outers on RockAuto and remember someone having some luck with those. Any performance ones that are idk billet lol
    May 2011
    Toronto, Ontario
    Try Mevotech Terrain Tough series.
    More Information for MEVOTECH TXES3571
    2006 300 SRT8 / 2012 300 SRT8
    Thanks Jay Z thanked for this post
    Likes Genestealer, chrismah, Hemissary, Jay Z liked this post
    Oct 2011
    South Jersey
    Quote Originally Posted by Jay Z View Post
    Which line of Moogs did you use? Their RK line is the cheaper less quality stuff. You need the problem solver series usually their K line stuff. But yes Ive heard good things about the Mevotech terrain tough line as well.
    2006 Dodge Charger R/T - 85mm Throttle Body, AFE Stage 2 CAI, 6.1 Intake Manifold, Modern Muscle Intake Adapters, 219/223 cam, 6.1 pushrods, Manley NEXTEK Valve Springs, 6.1 Timing Chain, 6.1 oil pump, Edelbrock Titech Headers, Flowmasters X pipe, Thrush 2 Chamber Mufflers, Flowmaster Resonators and tailpipes, 3200 Edge Converter, Mopar TCM, Tranzformer, Carbon Fiber Pistol Grip Shifter, 3.06, Brake Performance drilled and slotted rotors.
    Likes Jay Z liked this post
    Central Florida
    Moog Problem solvers. I put a set of outside one's on 10 years ago. Still no problems.
    Old 426 guy,
    Jim
    Dec 2018
    Hamilton Ohio
    I put the Pro forge ones on my 2008 300c.
    Jun 2013
    Quote Originally Posted by Jim McVeigh View Post
    Stock Suspension?
    Central Florida
    Yes. All stock front SRT stuff. In fact everything is same stuff from the factory. Just the tie rod outside ends were changed. Greased when the alignment is done yearly. Only needed a toe in adjustment done once in 130.000 miles.
    Feb 2011
    Sweden
    Bought Moog tie rods 9 years ago,,no problems.
