Results 1 to 2 of 2
    Jul 2014
    Winnipeg,MB
    Code c2112 low voltage abs pump help!
    Sorry its code C2116. also having angle sensor code. abs trac esp lights on in dash. Need some guidance. 06 300c. Battery was out 4 mths.The calibrating method does not seem to work. No codes show on predator. Snap on scanner does show those 2 codes. Upon further investigation the first code that comes up is U0125.
    Jul 2014
    Winnipeg,MB
    So I have the switch mod for esp cutoff. Uo125 is the code ohms from the switch are correct. Any ideas?
