Results 1 to 14 of 14
    Jun 2018
    anyway to start without a key?
    07 300c no keys. parts car/ want to see if it runs but dont want to buy a key. any way to do it?
    Feb 2017
    If you have it titled in your name you can go get a key cut at a dealer with the VIN# and the title and your ID.
    Calgary, Alberta
    RFID embedded in a proper / recognized key must be detected by RFID antenna / module located right at key location (reports to PCM) for SKREEM to disable No-Start condition.
    Jun 2018
    thanks guys. so the transponder is on the ignition. (the black box) so can i swap out the entire ignition with transponder from another car and hopefully have it work?
    its a written off srt-d and i just want to see if the engine is any good. really dont want to spend the money on a key just to part out the car.
    Feb 2017
    glendale az
    Quote Originally Posted by chrisf View Post
    you would have to swap out the key/key module and the pcm from another car that had a matching/working set.
    Jun 2018
    not worth the hassle. ill just pull the engine as-is. appreciate the help guys
    Mar 2019
    Illinois
    300's have pretty good anti theft so I don't believe you can start it without the key.
    ** 2006 300C SRT8 ** 426 fully forged Stroker 500 RWHP **Comp custom ground cam huge **4" 1 pc Driveshaft shop DS **Wavetrac 3.55 Diff **Paramount axles**Builder Bill Trans ** Viper 2900 Stall **BC Racing Coilovers **Drakes Strut Brace FT **Mopar Strut Brace R **Injen Powerflow CAI **Underdrive Pulley **Brembo 4 piston all around **American Racing SS Headers **American Racing SS catless mids **Corsa catback system **Professional Dyno Tune **BWoody sway bar links **Mishimoto Radiator ** Mishimoto/HPS Red silicone hoses **BBK 90mm TB **Ported Heads & Intake ground to match TB **
    Feb 2012
    Houston TX
    A mobile locksmith probably wouldn't charge too much to make just the regular sentry key for it (gray plastic with the security chip embedded.) Some can do the programming so be sure to ask. You don't need to cash up for a remote since you're just pulling the engine. A proven good running 5.7 is worth a hell of a lot more than an unknown 5.7...
    Richard
    Jun 2018
    talked to a customer of mine who can do a key for $200 but i have to bring it to him. thats a pain so i will bribe him with road runner parts to come here and program for me. lol
    Calgary, Alberta
    Note that you can program new keys yourself as long as you have two working FOBs that are already programmed and functioning...
    Feb 2012
    Houston TX
    Correct but do note this also includes the plain gray sentry key!
    Richard
    Jun 2018
    if i had two working fob's i would not need to post this thread. car has no keys. no fobs. nothing. looking around the car. owner got a new prescription for his ADD meds, bought A+W and crashed the car, hard. (anybody need some ADD meds?, they are in the car. lol)
    stuck in park, tow truck driver had to tie it to a tree in my yard to offload it. i am sure thats great for the trans.
    Calgary, Alberta
    We know...post #9 was missing the mark...
    The parking pall in the transmission will be just fine. Its when you try and engage Park while moving that it can be damaged (even though its spring-loaded).
    Mar 2019
    Illinois
    Had the tow truck driver known what he was doing he would have pulled the little storage tray out on the right side of the shifter and pushed the button to release the park lock lol
