Results 1 to 5 of 5
    Mar 2010
    So Cal
    Question Dash Replacement
    Hello All,
    It's been a while since I've posted on the forum but I need some help. I'm curious as to how difficult it is to change out the top of the dash on a 2005 300C. The original cover is warped from sun damage around the top vents. I was thinking maybe I can just replace the unit with new if it is not to difficult. I've searched the web without much luck. I thought maybe someone has seen something on how to do this job or maybe has done it themselves.
    Best Regards, Tim
    Sep 2010
    Bump
    2006 300C SRT8, Mopar cold air intake, Magnaflow shorty headers, cats and exhaust. KW Variant 2 suspension, Pioneer head unit, 10" Infinity sub with custom built box in the trunk.
    Oct 2011
    South Jersey
    Have you search this forum? I know guys have swapped them out. I recall threads with dash replacements in them.
    2006 Dodge Charger R/T - 85mm Throttle Body, AFE Stage 2 CAI, 6.1 Intake Manifold, Modern Muscle Intake Adapters, 219/223 cam, 6.1 pushrods, Manley NEXTEK Valve Springs, 6.1 Timing Chain, 6.1 oil pump, Edelbrock Titech Headers, Flowmasters X pipe, Thrush 2 Chamber Mufflers, Flowmaster Resonators and tailpipes, 3200 Edge Converter, Mopar TCM, Tranzformer, Carbon Fiber Pistol Grip Shifter, 3.06, Brake Performance drilled and slotted rotors.
    Dec 2007
    Riverside, California
    Hi Tim.
    It is a load of work, but it can be done.
    I've extracted complete dash assemblies and it takes a solid 4 hours. Just the pad shouldn't be nearly that bad.
    Michelle's dash had the same issue, as well as around the passenger side main dash vent.
    I removed all 3 dash vents, 2 top and one right side main, and used ABS glue and some Harbor Freight clamps, to glue the dash pad foam back to the plastic substrate.
    Took a couple of hours prep and cure time.
    Worked like a charm!
    Give me a call, if you need anything at all.
    Bob
    http://www.luxte.ch
    Lux Technologies
    Oct 2016
    Does Tim still exist? I have some questions about his VTCM and have tried direct messages and emails... Anyone have other contact info? Facebook even?
    Thanks in advance!
