Results 1 to 7 of 7
Thread: 300c problem
    Jan 2019
    300c problem
    Hi all!
    My first post on this forum.
    My 300c 3.0l diesel CRD has developed a problem.
    The lightning bolt, eps light and skid light are on. I have read the fault codes and they are p0676 and u0101. I know that the first one is the #6 glow plug, but the other is a mistery. I am able to delete the codes but they come back the next day.
    I live in the UK and Chrysler is no longer well supported (well, it never was really!).
    Any help/pointers very much appreciated!
    Sent from my Redmi 4 using Tapatalk
    Feb 2012
    Houston TX
    Welcome to the forums,
    U0101 is lost communication with the TCM (transmission control module) - if you search these forums for that code you will find lots of results. One of the threads has some good troubleshooting info in it -> Lost communuications with TCM, was intermittent, now constant.
    Richard
    Thanks georgedeal thanked for this post
    Nov 2009
    Niagara Region,Canada
    Could be the clockspring in the steering wheel, could also be the tone rings on the wheel hubs.
    Jan 2019
    Quote Originally Posted by foxtail View Post
    I suspect it may well be the tone ring(s) as the EVIC secret menu had ABS as LastChime.
    Cleared all the codes with torque pro yesterday and since then no lights have come back on. Tomorrow morning getting the glowplug changed.
    Jan 2019
    Glowplug got changed, but the other fault(s) are not fixed. The codes are too complex and they can't get involved. So, back to square one.
    They gave me a print out of the codes:
    PCM - Powertrain control module
    U0101 - Lost communication with TCM
    ABS - Anti Lock Brakes
    MIC/CCN - Mechanical Instrument cluster
    B1808 - Passenger door lock/unlock switch circuit stuck lock
    CGW - Central Gateway
    What now??
    Jul 2017
    Just a WAG but I would check the connections to the TCM and then follow the harness and look for chaffed wires.
    2012 300 SRT8: 22" Vossen wheels, Nitto 420 265/35/22 front and 295/30/22 rear, SLP Bigmouth II exhaust, Tuned by Hemifever, Mishimoto 180° stat, Legmaker Tru CAI, Billet tech Oil Catch can.
    Jan 2019
    Quote Originally Posted by Slated4Greatness View Post
    Thanks. Will do again tomorrow. Anyway, booked in at the stealership for next week (sick)!
