Page 3 of 3 FirstFirst 123
Results 31 to 41 of 41
  1. #31
    Dec 2016
    Greenville, south Carolina
    I think we've found the issue from the pics lol. That compressor does NOT look well at all.
    Doesn't have anything to do with my car leaking oil all of a sudden... Unless the belt ****ed up the compressor as well
    Sent from my XT1565 using Tapatalk
    2009 300c heritage edition/brilliant black/104000 miles/bone stock
  2. #32
    Dec 2016
  3. #33
    Aug 2012
    iowa
    Man that pulley looks goofy for sure. Have that looked at. Or if you can reach your hand down there and see if it is loose or separated?
    Not your oil issue but worth a shot
  4. #34
    Calgary, Alberta
    Quote Originally Posted by Vindiesel View Post
    Agreed, A/C clutch assembly not likely root cause. If oil is existing from the front crankshaft area, especially if the dampner is slinging oil everywhere, you should be able to see some shiny crank snout in front the crankshaft seal face...
    p.s. grab the front of the A/C clutch assembly and see if it move fore / aft or up / down :^)
  5. #35
    Mar 2017
    Bedford, Texas
    I've seen belts shred and eat all kinds of things...Radiator hoses, fan blades, bind up behind other pulleys and knock them out of alignment. Even had one shred while I was standing there with the hood open. I didn't know I could move that fast.
    I'm curious to know what the final word is, dampener ([email protected] lol) or whatever it was.
    Likes Vindiesel, Hemissary liked this post
  6. #36
    Feb 2008
    Bucks County, PA
    Once the belt shredded, who knows what happened. It may have gotten bound up and yanked on that compressor.
    Mike
  7. #37
    Dec 2016
    I'll be sure to report... Car has 130k miles bone stock
  8. #38
    Calgary, Alberta
    Please do; this is interesting. Good luck.
  9. #39
    Dec 2016
    Service advisor said the crank shaft pulley bolt was loose and was causing the issue with the belt shredding and oil leaking. Looks like I'm not paying a dime. They said it's not recall related with timing chain. They said they have seen them back off but maybe they see one case a year do it. They have no idea why it happens.
  10. #40
    Calgary, Alberta
    Hmm...likely not torqued to yield.
  11. #41
    Nov 2009
    Niagara Region,Canada
    A/C clutch still looks goofy. Looks to be a chev. clutch assy.
    Three Dodges I have ...all the a/c clutches are receded inward, as in they don't stick
    out that far...
