Page 6 of 6 FirstFirst ... 456
Results 76 to 88 of 88
Thread: Puzzled!
  1. #76
    Sep 2012
    Hempstead, Tx
    Quote Originally Posted by GTSDart340 View Post
    Losing prime would cause the valves to not open, which would increase compression and make the engine harder to turn over. Pretty sure oil pressure isn't the issue.
    1949 International KB2, 302/T5
    1968 Dodge Dart GTS, 340/727
    2006 Dodge Magnum R/T
    2016 Dodge Durango Limited
    That could very well be the issue. When it does the "Thing" we will call it, it does seem to spin over slower but no hint of compression strokes. Maybe all the valves are staying closed? Maybe thats why I don't hear the thump between cylinder strokes and the slow spinning someone mentioned in prior post. They said it sounded like a low battery.
    I notice twice a little puff of blue smoke come from the cold air intake when it does the "Thing"...
    Battleship Bismarck
    2015 Durango Citadel
    2012 Chrysler T&C
    2008 SRT8 Charger, Stockish!!
    2007 SXT Magnum
    2002 RT Intrepid
    2001 Ram 4x4
    2001 Town & Country Limited
    1999 Ram 1500 swb
    1998 2dr Neon Highline 5sp
    Member, Space City LX
    IG, oo_silversrt_oo
    Thanks reefstar thanked for this post
    Likes reefstar liked this post
  2. #77
    Oct 2010
    Eastern WA
    Quote Originally Posted by CUUDA View Post
    “Puff of blue smoke from intake” ... your valves are sticking open.
    It’s not a rocker issue (although that does not eliminate the rockers a being AN issue).
    Initial clacking noise,
    No compression
    Smoke coming from intake
    All sound like valves not seating fully closed.
    2005 ViperBit 3.5L
    Thanks CUUDA thanked for this post
    Likes doublechaz, GTSDart340 liked this post
  3. #78
    Mar 2016
    DE
    Smoke from the Imi take is important info.
    Is there any crankcase pressure when it doesn’t start.
    Use a remote starter switch so you can crank while watching everything.
    Likes GTSDart340 liked this post
  4. #79
    Sep 2012
    Hempstead, Tx
    Wasn't as bad today. It cranked the third time after the video and ran perfect. Use some ear phones to listen. Phone speakers suck.
    clatter - YouTube
  5. #80
    Jan 2016
    Here is what you can try. Let sit over night, if next day spins like it has no compression, immediately perform a compression test to see if valve are not seating.
  6. #81
    Mar 2016
    DE
    Do you have an amp clamp?
  7. #82
    Sep 2012
    Hempstead, Tx
    For monitoring amp draw??
  8. #83
    Mar 2016
    DE
    Yes. I'm curious what kind of amps its drawing during the crank.
  9. #84
    Sep 2012
    Hempstead, Tx
    Well I pulled the intake off and dont like what I see..
    Intake ports are super shiney but not wet. Looks like someone may have put something in my gas tank...........
    Looks like the valves were sticking open.
  10. #85
    Oct 2010
    Eastern WA
    Well there you go.
    Hopefully it hasn’t done any permanent damage to the cylinders as well.
    But that may explain why the engine was cranking slowly as well. Your cylinder walls may have residue on them as well.
    Do you think a good solvent wash will clean it out?
  11. #86
    Sep 2012
    Hempstead, Tx
    Soaked in brake cleaner. Once I get those ports and valvestems clean I will pour some Marvel Mystry Oil in the ports and let it soak. Also throw another bottle of Zmax in it.
    Injectors are toast! Got several sets of those laying around in the shop.... Pulled the new NGK Iridiums and they are covered in brown goo. Those are soaking as well. Not sure if it hurt the new fuel pump and regulator.
    Guess we will see if this corrects the problem or if further damage is done. I have another good set of heads ready too if needed.
  12. #87
    Oct 2010
    Eastern WA
    Puzzled!
    Put some gunk or sea foam in the tank. Disconnect the fuel rail and pump all the gas out of your tank. (Just jumper the relay switch and pump the tank dry)Then fill the tank half way and dump some Techron in there. Use different cleaners so they will break down different things. I would also absolutely pull the heads and clean everything, combustion chambers valves and pistons.
    I don’t think I would use ZMax. I think I would go heavy on an oil engine flush and clean all your fluids out.
    Then go right to Schaefer’s synthetic oil.
    You can clean the injectors with a can of injector cleaner, a valve stem and some jumper wires and a 9v battery if you want. (There are videos on YouTube) works great
  13. #88
    Oct 2010
    Eastern WA
    Quote Originally Posted by reefstar View Post
    One more thing... buy a locking gas cap.
