Page 2 of 8 FirstFirst 1234 ... LastLast
Results 16 to 30 of 107
Thread: Puzzled!
  1. #16
    Sep 2012
    Hempstead, Tx
    Hmmm. Maybe I need to keep the camera with me.. Seems everytime I have the camera ready it doesn't act up...
    Wonder if the bitch got some Christine metal in her?? 😂😂
    Battleship Bismarck
    2015 Durango Citadel
    2012 Chrysler T&C
    2008 SRT8 Charger, Stockish!!
    2007 SXT Magnum
    2002 RT Intrepid
    2001 Ram 4x4
    2001 Town & Country Limited
    1999 Ram 1500 swb
    1998 2dr Neon Highline 5sp
    Member, Space City LX
    IG, oo_silversrt_oo
    Likes reefstar liked this post
  2. #17
    Sep 2012
    Hempstead, Tx
    Little update.
    Added the Zmax and seems to have corrected the issue. A entire week and it starts up at the bump of the key.
    On that note,
    I picked up a Shaker hood for a cool $250. Looks decent!
    https://i.imgur.com/bo2Gdd4.jpg
    https://i.imgur.com/QqvNcYG.jpg
  3. #18
    Sep 2012
    Hempstead, Tx
    Got it inspected and tagged. Went for a 100 mile drive parked it. It did fine throughout the drive. Next morning this,
    Dodge 3.5 Issues. - YouTube
  4. #19
    Oct 2010
    Eastern WA
    Quote Originally Posted by CUUDA View Post
    Sounds like a bad starter to me. It’s cranking over very slowly.
    2005 ViperBit 3.5L
  5. #20
    Sep 2012
    Hempstead, Tx
    Nah... Not the starter. At the begining of the video you can hear horrible clacking sound then the oil pumped up and the clacking went away.. Then you can hear it spin over like it has no compression. At the end of the video it starts hitting compression.
  6. #21
    Dec 2016
    Do you have actual compression numbers? If the compression is low (all plugs out, wide open throttle and cranking with a gauge and testing all the cylinders), try a wet compression test by adding a bit (maybe a teaspoon size amount) of engine oil to the top of the pistons through the spark plug hole. It will smoke like hell for awhile if it starts but if your numbers go up on the gauge, you know it is a piston ring issue. If the numbers stay low then you know it is an upper end issue like valves. Good luck.
    Thanks CUUDA thanked for this post
  7. #22
    Oct 2010
    Eastern WA
    Puzzled!
    There’s no way you don’t have compression. You would know. There would be oil clouds following you everywhere (bad rings).
    Or your valves would all need to be stuck open, that’s not gonna happen, or your spark plugs aren’t in (and you would know that)
    The engine is turning over slowly. The clacking sound could be the solenoid kicking the starter into the flex plate.
    Even if it isn’t you’re starter, then your battery is toast.
    Or ... your valves are not opening, and your not getting any fuel or air, and your only building compression. It does not sound at all like it’s freewheeling.
    Didn’t you say you rebuilt your rocker arms?
  8. #23
    Jun 2017
    Phoenix, AZ
    It could be the starter gear isn't kicking out, so your hear the starter turning over, but since the engine isn't spinning it sounds like no compression. Every once in a while the gear kicks out and the engine cranks over normally. That's my bet. How do you know it's the oil pump you're hearing?
    1949 International KB2, 302/T5
    1968 Dodge Dart GTS, 340/727
    2006 Dodge Magnum R/T
    2016 Dodge Durango Limited
    1949 International KB2 "Mater" 302/T5
    1968 Dodge Dart GTS "The Drat", 340/727
    2006 Dodge Magnum R/T the "Wagnum", 5.7/auto
    2016 Dodge Durango Limited, 3.6/auto
    Oh Drat! Racing
    Likes jdm7, reefstar liked this post
  9. #24
    Oct 2010
    Eastern WA
    Puzzled!
    Quote Originally Posted by GTSDart340 View Post
    I can’t think of anyway that it could be spinning with no compression and not have other totally obvious signs. Smoke or steam everywhere.
    He could have lost a couple of cells on his battery, enough to hold a charge, but not enough CCAmps on startup.
    Try another battery if you can. If that has no change... it’s got to be the starter. Crank it over and watch the accessory belt. If it’s not moving, or it’s moving slowly...
  10. #25
    Jun 2017
    Phoenix, AZ
    Quote Originally Posted by reefstar View Post
    Is the engine really spinning over though?
  11. #26
    Oct 2010
    Eastern WA
    Doesn’t sound like it to me.
  12. #27
    Mar 2016
    DE
    Sound alike the starter is free spinning.
    Prop your phone up on something and take a video of the belts while cranking.
    Likes jdm7, GTSDart340, reefstar liked this post
  13. #28
    Sep 2008
    So-Cal, Covina
    Stand in front of the engine bay while someone else cranks it over. May want to pull the starter and see what the gears look like.
    - 2007 Charger 3.5 SXT, Sold 8/2017
    - 2017 Charger 5.7 R/T Super Track Pak, Ceramic Tinted windows, Widebody staggered wheels and tires, tinted Tails/sidemarkers, RBG Demon Eyes, Whole car splitter kit, 8000k HID Headlights, ZL1 rock guards, 2021 Hellcat widebody Spoiler, Ikon rear diffuser, 3M matrix black dual stripes, Carbon fiber interior, Carbon fiber steering wheel w/ red leather, Razors edge strut tower brace, Hemi Fever Tunes, Flowmaster Super 10's, Diablosport Intune i3/PCM.
    Best 1/8 mile time: 8.860 @ 82.81mph
  14. #29
    Feb 2017
    glendale az
    When this starts acting up have someone crank it and use a can of start up fluid and spray some in the throttle body and see if it fires off, might want to check for any fuel bleed off with pressure guage also.
  15. #30
    Aug 2020
    Southfield, MI
    Old trick I've heard - tap the starter with a hammer to see if you can shake things loose. How does a hammer fix a starter? | Parkside Motors
