Page 21 of 21 FirstFirst ... 11192021
Results 301 to 306 of 306
  1. #301
    Oct 2010
    Eastern WA
    My 3.5L EPIC waste of time!!! Why not!
    Quote Originally Posted by tf34mech View Post
    Don't they make a shorter nose drive for the M90? That might make installing the throttle body easier. Also it looks like you're going to have to paint the harness cover on the right valve cover gold.
    LOL. The SC isn’t going on this engine (the good one). It’s going on the Magnum engine swap. (I bought it with a seized 2.7). And this engine will be Plum Crazy(the color).
    I may actually need to install 2 Right valve covers, that way it will be cleaner to rotate the coils around to make more clearance for the SC to fit. I can run the wires from the harness into the coils from the outside in.
    Oh, and yes I may need to track down shorter nose. Otherwise I will 90 off of the back of the SC into the TB.
    2005 ViperBit 3.5L
  2. #302
    Oct 2010
    Eastern WA
    Quote Originally Posted by TRQmonster View Post
    It just feels like either stock or especially with cam and forged pistons, you're engineering a bottleneck in that supercharger. Which was evidently super cheap. But any old procharger or torqstorm would be capable of 700+ hp and on the engine you're describing you could likely pull that off.
    You may be 100% right. But 700hp isn’t my goal (this time).
    Like I said, I’m trying to use an easy to find, inexpensive SC (and Eaton is reliable as well).
    If I push 400hp, that would be awesome. Keep in mind I have a 4 speed in the car, and going much over 400hp could create transmission issues. Don’t want to go there. (But I have a plan for that as well if needed).
    If I need more boost, I can look into smaller pulleys etc.
    I’d love to see some of the 3800 research you’ve found.
  3. #303
    Oct 2010
    Eastern WA
    There is a shorter snout for the M90 for both the Mustang and Jaguar. So that shouldn’t be a problem.
    Also looks like there is a intercooler available too..
    3800 Supercharged Top 5 Mods | ZZPerformance - YouTube
  4. #304
    Jun 2012
    West Texas
    Quote Originally Posted by RT NOMAD View Post
    Just thought I'd post a pic of a 3.5L with a different throttle body configuration.
    i need info on this intake asap.. lol Seriously. PM me if you want. Where was it made, how much etc (If you don't mind).
  5. #305
    Jun 2012
    West Texas
    So I cant see the photos but I did some clicking around on the racingcalcs website, and mathematically their numbers make sense. But it doesn't seem to take into account the size or flow rate of the supercharger.
    Can a 3.5l motor make 80hp on a 10-71 blower with 4psi? Sure.
    But am I wrong in getting hung up on the supercharger itself? Like a smaller blower is going to make more heat, increasing Temps, increasing "boost pressure" while reducing power.
    So I agree with your point I just don't understand how that plays into a SPECIFIC supercharger or application.
    In my case I had 187rwhp stock. added a powerdyne SC and was making 345rwhp. Ran 14,15 @102 in the 1/4 consistantly fully loaded with an audio setup and full tank of fuel. I've sence rebuilt the bock using a 4.0L block from a Dodoge Nitro, added big valve heads, blower cams etc. Should be around 420-450rwhp. Like reefstar, I wanted to use off the shelf parts. not going for max power... I want reliability. 345rwhp @ 10psi comes about to 15.8hp per pound of boost.
    Quote Originally Posted by reefstar View Post
    Yeah bud I think 315rwhp is problly that 42RLE transmissions limit. 2nd gear starts to hate you at WOT around that power band. It will have a hard time shifting at around 40 mph. BUT I was using 3.90 rear from a magnum so you nerver know.... lol
    Thanks TRQmonster thanked for this post
    Likes reefstar, TRQmonster liked this post
  6. #306
    Mar 2012
    NE Florida
    Nice setup I see a modified hood in your future.
    Stage 2 Intercooler System for 3800 Series II and III | ZZPerformance
    Likes reefstar liked this post
