    Feb 2012
    Okeechobee, Florida
    Install SRT stuff in an SXT
    I had been reading about others upgrading their SXTs, and I have always wanted to have the leather steering wheel and buttons on the wheel to control the radio. Well, I decided to go all out. I got a steering column w/wheel and instrument cluster from a 2010 SRT. I installed the SCM, clock spring and leather wheel to my original column. The gauge cluster was a straight up swap. Once all this was done, I fired up the AppCar software and started looking through things that I wanted to change. I now have DRLs running through the high beams. Started raining, so I did not get a chance to really work through all the settings. I have not, as yet installed the uconnect device, but once that goes in, I will have a compass shown on the dash. I have had zero issues so far and I think as long as I don't go nuts changing settings, things will probably be good to go. I took a few pics during the swap and thought I would post them up to show others. Basic things like how to disconnect the dash panels are located all over the site, so just do a bit of sniffing around, you will find what you need.
    Ron
    ...Semper Fidelis...
    2010 Dodge Charger SXT
    BT catch can
    BT emblems on front and rear
    Power Stop Z26 Extreme drilled rotors
    R/T leather steering wheel w/switches
    R/T EVIC cluster (mostly working)
    Likes hotrod1, sojiaraggs9000, BlackAce liked this post
    Feb 2012
    Okeechobee, Florida
    Just an update (not that anyone cares), I have installed the RT gauge cluster, leather steering wheel w/controls. I have also installed Homelink. I have also changed a few settings with the AppCar software, like DRLs and a couple of other things. I think I need to either change out or have my TIPM programmed to get all the EVIC functions working. I think I will be keeping the old girl now.
    Aug 2009
    Quote Originally Posted by blkadder View Post
    I use that software also and I have a license for my Avenger. It's the cat's pajamas for sure. I was able to enable many options I didn't have. I'm also on their beta.
    05 Magnum AWD SXT Hemi Swap
    instagram.com/hemisxt
    Likes tf34mech liked this post
