Results 1 to 11 of 11
    Mar 2018
    Building a SLEEPER ....😁
    I’v been working on turning my 3.5 v6 wagon into a sleeper.......I call it BMW passing gear..... PISSES them off when a SXT station wagon pulls away with the tires smoking πŸ‘ŠπŸ˜...... 3E4C9709 5597 4D38 8FD3 B064DB1C01B6 - YouTube
    Likes madcoder liked this post
    Dec 2008
    NH
    Sleepers are fun...and some of the Bimmer drives get butt hurt very easily lol
    Sep 2016
    Liked and subscribed! Supercharged 3.5?
    Mar 2018
    Running a Zex 75hp wet shot of Nitrous at the moment...And down one heat range in the plugs . It pulls WAY harder with a fully charged and heated bottle...Next is the transmission ... upgrading the valve body , clutches , torque converter , a shift kit and line lock ...Got plans for the block and heads as well
    Mar 2018
    Update
    the transmission has been rebuilt
    2500rpm high stall , high friction clutches ,
    updated valve body and a shift kit
    20/35/265 NITTO 555 on the rear
    20/35/245 NITTO 555 on the front
    on the way is a set of Inertia 1.2 cams
    a Diablo Trinity 2 tuner and long headers
    it’s getting true dual exhaust and I’ll be
    running twin NOS bottles and going up
    25hp on the jets
    Sep 2018
    Quick question. When you separated the engine and transmission, was there a spacer plate in between. I pick up a car with the engine out, so I am not sure if it is supposed to have one.
    Mar 2018
    No spacer plate
    The flex plate and ring gear bolt directly to the crank
    Jun 2012
    West Texas
    Quote Originally Posted by Thumpper View Post
    Update
    25hp on the jets
    Does the Magnum come from factory with the W5A580 (NAG1 v6 version)?? Reason I ask is because I thought the stock stall was tested at somewhere around 2800??
    Mar 2018
    I’v got the 4 speed 48LRE transmission
    with the camshafts I am running the car
    is useless under 2500rpm anyways so it
    worked out well
    Mar 2018
    These new camshafts are sick , lost a bit of
    bottom end torque but she pulls like crazy
    up top....
    hitting the Nitrous at 60 kph in 1st it hammers you
    back in the seat... very impressive
    Feb 2019
    How where you able to get a hold of someone at inertia? I have tried a couple times and haven't had any luck.
