I've been having problems with my car starting. 06 Chrysler 300 2.7L. Most of the times is starts. But once in a while it wont. I will have to play with the negative battery cable I order to get it to start. I replaced the cable yesterday with a new one. It started fine yesterday. But this morning it didnt want to start when I pulled into the store. I went and rechecked my connection to the negative battery cable. I removed all the negative cable for my amp connections. And retightened the negative battery cable. So far so good. Should I be checking anything else for a short? Also now i tried to start it and it clicked on the 4th try it started. Starter or Ignition?
Thanks,
Ramiro
Sent from my SM-N975U using Tapatalk
Thanks,
Ramiro
