all 2.7L owners should check their water outlet housings for coolant leak. I have had to replace two of them in the last week. both '06 chargers with less than 5,000 km (3,000 miles). the first one was towed in because the housing cap popped off. the second one I noticed was leaking during first maintenance service. the leak is from the seam between the housing and the parallelogram (eraser shaped) cap. the cap is glued to the housing and in these two instances, the glue seems to have failed. if yours is leaking, see your dealer asap. if the cap pops off, coolant will be expelled all over the engine compartment.
I have some pics but can't post them. if someone can post them for me, please pm me your e-mail address and I'll send you the pics.
thanks.
thanks.
