I bought a '16 Scat Pack rear cradle to swap into my '06 SRT8 Charger. While I have the cradle out are there some upgrades that would be worthwhile? New rear cradle bushings? Rear sway bar (it currently has a 19mm factory unit)?
I have them in my car that I drive every day. I don't think I can even feel the difference other than when I launch at the track. I have a 1 pc alum drive shaft as well. I don't feel that, but it does kind of broadcast a clunk I have in my differential. It's a pretty subjective thing. Almost every modification I've made has sacrificed some level of comfort, and I would be lying if I said my car is comfortable, but it feels, sounds, and drives great in my opinion, and that's better than a luxury cruiser. My wife on the other hand wouldn't ride around the block in it.
After looking into the rear sway bar options, I'm not sure there is anything out there that would be much of an upgrade. The Scat Pack rear sway is 19mm, the police sway is 20mm, and the other aftermarket sways are in the same ballpark.
For adjustable control arms, is something like this from BMR recommended or something like this from Spohn?
Just talked to BFNY and they don't have any of the aluminum CTP bushings in stock. He's trying to find another machine shop to fabricate the bushings but so far there is no ETA.
I don't mean to derail your thread, but what is the advantage of the change you are making? I have a 06 Maggie, is the swap something I should consider?
The ZF diff in '15+ Scat Packs and Hellcats has a 230mm ring gear (vs 226mm in the Getrag and 215mm in the older LX vehicles) and 4 mounting points for the diff in the cradle vs 3 in the earlier cradles. Basically a direct bolt in cradle with a diff that's stronger than the Getrag.
Related Threads
LX Forums Forum
5.2M posts
123K members
Since 2004
