  • Post Photos of your car
  • Meet local members
  • Learn more about your car!
Go Back   LX Forums | Dodge Charger Challenger Magnum | SRT8 | Chrysler 300 Forum > The Knowledge Base > Articles > Troubleshooting
Troubleshooting Troubleshoot your LX vehicle's symptoms
Click for instructions on how to post an article in the Knowledge Base
Reply
Article Tools Display Modes
  #1
Old 07-17-2007, 02:10 PM
kudasai's Avatar
kudasai kudasai is offline
medium pimpin
kudasai should be on American Idol.  A Star!kudasai should be on American Idol.  A Star!kudasai should be on American Idol.  A Star!kudasai should be on American Idol.  A Star!kudasai should be on American Idol.  A Star!kudasai should be on American Idol.  A Star!kudasai should be on American Idol.  A Star!kudasai should be on American Idol.  A Star!kudasai should be on American Idol.  A Star!
shifter problems and fix
Well, I am posting this because I have heard of one or two people having the same prolem, and while most people still have their warranty, you wont have it forever. So if this should happen to you, now you have a way to keep from getting ripped off at the stealership. And from what I saw, this will become an issue at some time or another. I don't know if the shifter is common for all the rt's or not, so i posted it here.
Basic situation: car would not come out of park. It would start fine, but just wouldn’t shift. And the shifter felt like it was binding mechanically instead of any electronic inhibits.
After tearing out the trim pieces on the console, I found that there were two pink levers on the shifter.
I pressed the one on the back(per the factory manual instructions) with no luck. However, there is a larger one on the front which was color coded the same bright pink.
After monkeying with it a few seconds, I found that I could swivel it out of the way and engage the shifter. This at least got me on my way until I could find a better solution.
Well today I had the time to take it out and look at it. And a nagging suspicion I had was confirmed. Once I pulled the shifter out, I shook it, and two small pieces fell out.
It seems the large swiveling lever in the front of the shifter works with the ignition lock. It isspring loaded open, and when the key is pulled a solenoid closes, actuates a cable, and pulls the lever to hold the shifter in park. When the solenoid is opened(key back in) the cable goes slack, and the spring pulls the lever open, allowing you to take the car out of park.
And the parts that fell out?
Those would be the spring, and the flimsy plastic arm that broke off. So here we have a spring the size of a dime that can render inoperable a 35k dollar car. Wonderful. Especially since if it fails, it is designed to do just that.
Even better, when I went to the dealer to get another, the guy just laughed and told me that they don’t sell that part, you have to buy the whole shifter for 127 dollars. Don’t get me wrong, I sadly expected that exact response. I just thought its nifty that only when you expect the worst does a 5 star dealer live up to your expectations.
So I decided to fix the problem myself. I used 20 thousandths lockwire that we use on the aircraft, a small hole in the lever, and a few minutes to put everything back together. The pictures should be self explanatory. I actually spent more time typing this and inserting photos than it took to fix the problem, but felt it well worth it. With the cost of a tow, an hour or more labor to have the part installed, scratched interior parts from them doing the work, and worst case a rental car, you could be out 3 or 4 hundred dollars simply because of a poorly designed 50 cent spring.
So even if it hasn’t happened yet, just read and remember. A flimsy as the little plastic arm was that holds that spring, I’m pretty sure that they will be a common problem as the cars start to age.
Enjoy!
05 magnum rt
83 300TD with waste veggie kit
92 nighthawk 750.
burn vegetable oil to work, burn rubber on the weekends!
Sponsored Links
  #2
Old 07-17-2007, 02:18 PM
TWIST3D BLACK MAG's Avatar
TWIST3D BLACK MAG TWIST3D BLACK MAG is offline
GEORGIA LX CLUB
Ride: 2005 Dodge Magnum 2.7L V6
TWIST3D BLACK MAG IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!TWIST3D BLACK MAG IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!TWIST3D BLACK MAG IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!TWIST3D BLACK MAG IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!TWIST3D BLACK MAG IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!TWIST3D BLACK MAG IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!TWIST3D BLACK MAG IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!TWIST3D BLACK MAG IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!TWIST3D BLACK MAG IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!TWIST3D BLACK MAG IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!TWIST3D BLACK MAG IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!
Great Write up !!!!!
Beans to you !!!!
Custom Signature by Hazman
Georgia LX Club:
  #3
Old 07-17-2007, 02:37 PM
Super T's Avatar
Super T Super T is offline
Ride: 2006 Dodge Magnum SRT8
Super T parents' must be siblings.  How else could he be this awesome?Super T parents' must be siblings.  How else could he be this awesome?Super T parents' must be siblings.  How else could he be this awesome?Super T parents' must be siblings.  How else could he be this awesome?Super T parents' must be siblings.  How else could he be this awesome?Super T parents' must be siblings.  How else could he be this awesome?Super T parents' must be siblings.  How else could he be this awesome?Super T parents' must be siblings.  How else could he be this awesome?Super T parents' must be siblings.  How else could he be this awesome?Super T parents' must be siblings.  How else could he be this awesome?Super T parents' must be siblings.  How else could he be this awesome?
stellar write-up!
I DRINK ROYAL PURPLE! WHAT NOW?!
> 2006 Silver SRT-8 magnum, adopted 9/9/06 with 36 miles, groups I, II, &III.
* tinted LED Tails * Mopar Remote Start * Stainless Airhammer * Coated Kooks Longtubes * PPP Heads, Cam, and Converter * Alpine R10 Subs/AoN Enclosures * 20" Black AR 311's w/ Nitto 420's * Corsa cat-back * Front Window Tint * Ratman Hatch Button Mod * Hotchkis Sways * BT Underhood Bling * Polished Intake Manifold * Autodim Drivers Mirror *
  #4
Old 07-17-2007, 04:15 PM
jimhrabe's Avatar
jimhrabe jimhrabe is offline
draggin ass running 12's
jimhrabe doesn't look like much now, but drinking milk does wonders
I just found this and got the wives car back last Saturday after having this same problem!! Thanks for the info!
1991 GMC Syclone bagged and 4linked laying frame
1955 Chevy belair hardtop race car
2002 2500HD 6in lift rollin 35's
2006 Dodge Magnum(wifes car)
  #5
Old 07-17-2007, 07:22 PM
32Noir's Avatar
32Noir 32Noir is offline
Not Y3K compliant
32Noir should be on American Idol.  A Star!32Noir should be on American Idol.  A Star!32Noir should be on American Idol.  A Star!32Noir should be on American Idol.  A Star!32Noir should be on American Idol.  A Star!32Noir should be on American Idol.  A Star!32Noir should be on American Idol.  A Star!32Noir should be on American Idol.  A Star!32Noir should be on American Idol.  A Star!32Noir should be on American Idol.  A Star!
Excellent job. Thanks for this. I've already saved it for later..........
If everything is coming your way, you're in the wrong lane"
2006 Magnum SRT8 Silver - Grps I,II,III,sunroof,side air bags;CSRT8 rims; auto headlights;retro shift knob;SS Airhammer; Ultimate Pedals;SRT8 mats;rebadging; Magnaflows;Diablo;180 T-Stat;22Elite console cover;strut tower brace; rear wiper delete with Chrysler emblem; BT catch can, & other stuff; AAC Halos; CBD CF hood, & underhood goodies.
32 Ford 3 Window (32NOIR); 6.71blown Mouse motor; lots more
  #6
Old 07-18-2007, 11:55 AM
doughboy's Avatar
doughboy doughboy is offline
Me no speakie engrish?!??
Ride: 2005 Dodge Magnum 3.5L V6
doughboy .........If I were a chicken, I'd be impeccabledoughboy .........If I were a chicken, I'd be impeccabledoughboy .........If I were a chicken, I'd be impeccable
Lol. This JUST happened to my shifter assembly. Luckily under warranty. So no major issues, other than having to way almost a day or something for the right part to show up.
Edited to add:
Just for anybody that decides to do this out of warranty at a dealer. Not certain how many hours or the hourly rate for the labor.
Description List Price - Unit Price Labor
4578029A SHIFT ASM 54.85 54.85 179.50
Parts and Labor total: 234.35
  #7
Old 09-15-2007, 12:49 PM
BobF's 6POINT1's Avatar
BobF's 6POINT1 BobF's 6POINT1 is offline
I'm tryin' to think but nuttin' happens
BobF's 6POINT1 Kiss my navel,   I am up there in beansBobF's 6POINT1 Kiss my navel,   I am up there in beansBobF's 6POINT1 Kiss my navel,   I am up there in beansBobF's 6POINT1 Kiss my navel,   I am up there in beansBobF's 6POINT1 Kiss my navel,   I am up there in beansBobF's 6POINT1 Kiss my navel,   I am up there in beansBobF's 6POINT1 Kiss my navel,   I am up there in beansBobF's 6POINT1 Kiss my navel,   I am up there in beansBobF's 6POINT1 Kiss my navel,   I am up there in beansBobF's 6POINT1 Kiss my navel,   I am up there in beansBobF's 6POINT1 Kiss my navel,   I am up there in beans
Just happened to me yesterday. Now time to see if I can have the dealer look at it while I stop by for ten minutes instead of keeping it all day to tell me they need to order the part.
(Waiting patiently for the 2011/12 300C SRT 8)
  #8
Old 09-15-2007, 01:33 PM
MattRobertson's Avatar
MattRobertson MattRobertson is offline
giggity
Ride: 2005 Dodge Magnum RT
MattRobertson is a modest person, with so much to be modest about.  Envy them.MattRobertson is a modest person, with so much to be modest about.  Envy them.MattRobertson is a modest person, with so much to be modest about.  Envy them.MattRobertson is a modest person, with so much to be modest about.  Envy them.MattRobertson is a modest person, with so much to be modest about.  Envy them.MattRobertson is a modest person, with so much to be modest about.  Envy them.MattRobertson is a modest person, with so much to be modest about.  Envy them.MattRobertson is a modest person, with so much to be modest about.  Envy them.MattRobertson is a modest person, with so much to be modest about.  Envy them.MattRobertson is a modest person, with so much to be modest about.  Envy them.MattRobertson is a modest person, with so much to be modest about.  Envy them.
More beans coming your way. Fantastic write-up. This should go into the KB.
EDIT: ok duh. its already in the KB :D
displacement: 6.4L, rwhp: 431, rwtq: 442, attitude: bad. Mods list is ridiculous. I'm a Classic car Insurance guy.
Feel free to ask questions. on things like insuring your mods or what Agreed Value means to you.
  #9
Old 09-16-2007, 01:03 AM
Mighty Noid's Avatar
Mighty Noid Mighty Noid is online now
Needs a bigger cam and a set of heads!
Ride: 2006 Dodge Charger RT
Mighty Noid has the wisdom of youth and the energy of age.Mighty Noid has the wisdom of youth and the energy of age.Mighty Noid has the wisdom of youth and the energy of age.Mighty Noid has the wisdom of youth and the energy of age.Mighty Noid has the wisdom of youth and the energy of age.Mighty Noid has the wisdom of youth and the energy of age.Mighty Noid has the wisdom of youth and the energy of age.Mighty Noid has the wisdom of youth and the energy of age.Mighty Noid has the wisdom of youth and the energy of age.Mighty Noid has the wisdom of youth and the energy of age.Mighty Noid has the wisdom of youth and the energy of age.
Quote:
Originally Posted by 6POINT1
View Post
Well I am glad to know that this was the issue. Even if the dealer can't fix it in time... you can do this quick fix for this upcoming weekend.
I am also glad that my memory isn't gone yet...
  #10
Old 09-16-2007, 06:23 PM
kudasai's Avatar
medium pimpin
i'm glad to see that this fix it is still getting mileage. thanks for the beans everybody!
05 magnum rt
92 nighthawk 750.
  #11
Old 03-20-2008, 10:39 PM
Davesatdoasisbar's Avatar
Davesatdoasisbar Davesatdoasisbar is offline
Belly your cans up on to the Oasis Bar
Davesatdoasisbar ....is so cool...they keep my diet Dr. Pepper coldDavesatdoasisbar ....is so cool...they keep my diet Dr. Pepper coldDavesatdoasisbar ....is so cool...they keep my diet Dr. Pepper coldDavesatdoasisbar ....is so cool...they keep my diet Dr. Pepper coldDavesatdoasisbar ....is so cool...they keep my diet Dr. Pepper coldDavesatdoasisbar ....is so cool...they keep my diet Dr. Pepper coldDavesatdoasisbar ....is so cool...they keep my diet Dr. Pepper coldDavesatdoasisbar ....is so cool...they keep my diet Dr. Pepper coldDavesatdoasisbar ....is so cool...they keep my diet Dr. Pepper coldDavesatdoasisbar ....is so cool...they keep my diet Dr. Pepper coldDavesatdoasisbar ....is so cool...they keep my diet Dr. Pepper cold
The old days were so much easier
  #12
Old 03-21-2008, 08:16 AM
goldsmi goldsmi is online now
Active Xeroid
goldsmi could kick Chuck Norris' buttgoldsmi could kick Chuck Norris' buttgoldsmi could kick Chuck Norris' buttgoldsmi could kick Chuck Norris' buttgoldsmi could kick Chuck Norris' buttgoldsmi could kick Chuck Norris' buttgoldsmi could kick Chuck Norris' buttgoldsmi could kick Chuck Norris' butt
'Just for anybody that decides to do this out of warranty at a dealer. Not certain how many hours or the hourly rate for the labor.
Parts and Labor total: 234.35'
OR
Just throw the pink plastic pawl in the trash - problem fixed forever $0.00
Thread titles that contain 'OMG' or 'WTF' are not read.
The word is spelled 'Definitely'.
There is a Y and an O in the word 'you'. 2 is not a word.
Learn how to use 'to', 'too', and 'two'. Learn how to use 'there', 'their', and 'they're'.
The things that stop your car are 'brakes'.
Tires are mounted on wheels, A toilet bowl has a rim.
It's only 'old school' if you are 12 years old - in which case it is past your bed time.
You are probably not the first person to ever have that problem - use the Search function, then use it again.
I don't care what you think of my car, I like it just fine.
  #13
Old 05-04-2008, 05:01 AM
Magnum PI's Avatar
Magnum PI Magnum PI is offline
Bike Wagon
Magnum PI is accepting applications for their fan clubMagnum PI is accepting applications for their fan clubMagnum PI is accepting applications for their fan clubMagnum PI is accepting applications for their fan club
Well I'll be. This just happened to me tonight when we were about to go out for dinner. I started it up but couldn't shift out of Park. I quickly went to LXFORUMS to see who would know about this, and sure enough here is the great heads up article.
I will see if it is covered under my extended warranty, but sad if it really is due to a cheap plastic part. I may poke around in the morning to see if I can at least get it out of park so I can drive it to the dealership. Again, LXFORUMS to the rescue. Thanks Kudasai for the great write up! - MPI
Magnum PI - Hilo, Hawaii
05 Black Magic Magnum RT, Zoomers, Eibach pro-kit springs & Dampers, Voxx Mizanos w/ Toyo Proxes4 255/45 x 20, Frankentake III
00 Trek 5200 USPS Bike
  #14
Old 05-04-2008, 05:50 AM
joe incognito's Avatar
joe incognito joe incognito is offline
Ron 4 of 4
joe incognito ....is so cool...they keep my diet Dr. Pepper coldjoe incognito ....is so cool...they keep my diet Dr. Pepper coldjoe incognito ....is so cool...they keep my diet Dr. Pepper coldjoe incognito ....is so cool...they keep my diet Dr. Pepper coldjoe incognito ....is so cool...they keep my diet Dr. Pepper coldjoe incognito ....is so cool...they keep my diet Dr. Pepper coldjoe incognito ....is so cool...they keep my diet Dr. Pepper coldjoe incognito ....is so cool...they keep my diet Dr. Pepper coldjoe incognito ....is so cool...they keep my diet Dr. Pepper coldjoe incognito ....is so cool...they keep my diet Dr. Pepper coldjoe incognito ....is so cool...they keep my diet Dr. Pepper cold
beans to you my friend, good post.will keep this in mind if (or should I say when) this happens to me.
Ron (Yup, another one)
- '05 Maggie RT - no mods...yet
  #15
Old 05-04-2008, 11:57 AM
Walt SRT8's Avatar
Walt SRT8 Walt SRT8 is offline
Finding the Line
Ride: 2006 Chrysler 300C SRT8
Walt SRT8 should be on American Idol.  A Star!Walt SRT8 should be on American Idol.  A Star!Walt SRT8 should be on American Idol.  A Star!Walt SRT8 should be on American Idol.  A Star!Walt SRT8 should be on American Idol.  A Star!Walt SRT8 should be on American Idol.  A Star!Walt SRT8 should be on American Idol.  A Star!Walt SRT8 should be on American Idol.  A Star!
Great Write Up..........Great Solution.
Laguna Seca 1.56.24 (4-22-08) 52*F 300C/SRT8 SVS Tuned
398.91 RWHP / 394.08 (ft/lbs) Torque - (2-21-09) N/A 6.1L Stock Heads & Internals
Reply
Article Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
LX Forums Magnum Charger 300C
powered by crystaltech
