| Serving the LX Community for 5 years. 2004-2009 |
300 General Discussion
Discuss the Chrysler 300 in here |
#1
300C pull to the right
My 300C has the dreaded pull to the right. SuperDave sent me a link to a discussion board that touches on this as a TSB FROM Chrysler. (Thanks Dave). My dealer does not SHOW any active TSB for a "pull to the right", however. I have an appointment on Thursday to get it looked at. DOes anyone else have this problem? By the way, I have been checking here everyday for the TSB:
http://www-odi.nhtsa.dot.gov/cars/pr.../tsbsearch.cfm |
#2
Re: Pulls to the right, what's going on?
Hi folks,
Picked up my new 330C last Friday and on the way home noticed the car has a tendency to go slightly to the right. At first I thought it was the curvature of the road until I had come to a flat section of road. Same thing happened. How many people are HAVING this problem? Jerry in De. |
#3
Lean machine
My 300C veers more right than Pat Buchanan, in fact it requires that I keep at least one hand on the wheel at all times (which makes eating a burger while talking on the phone and entering info INTO my laptop extremely difficult while negotiating curvy roads at a high rate of speed).
I've only logged about 150 miles, but the lean machine is definitely intent on hugging curb. I too thought it was the road at first, but it's all the time, every surface, more noticeable on the freeway than anywhere else. I am cursing myself for not catching it when I picked the car up...but...uh...I was overcome with excitement and just wanted to leave the ditzy salespeople behind and carve up some asphault. Which I have! It leans, sure, but man is this car a blast! Where can I get this TSB in writing? I'd like this fixed before I slap new wheels on it. |
#5
Whats the fix? Revised Toe/Caster/Camber specs? Shims? Anyone know if this is being corrected on car be built now, like new orders?
Robert and Alice - Engaged 12/13/2008, NYC Central Park on "Gothic" footbridge
#6
Well, this does not inspire confidence. What seems strange is that the degree of the pull is different, but it's always to the right. Anyone have an idea what is wrong?
-GWAZI '96 Dodge Ram 1500 ("Big Puppy") '95 Volvo 850 GLT ("Teh Wolwo") '72 Pontiac LeMans Convertible ("Ghetto Cruiser") |
#8
If they CHECK the alignment and all is ok, it could be a tire problem. To CHECK it, have them rotate tires front to back. If car rides better, then it may be a bad tire. This was a problem in the early 300Ms but those cars came with Goodyears.
2000 silver 300M loaded... |
#11
Not. That would be known as a lemon....
Visit Dodge Magnum Links on Runlevel6.com |
| Sponsored Links |
#13
Chris ~ '01 LHS • '01 Dakota Sport • '04 Sebring Convertible • '05 Grand Caravan
#14
Haven't read it. In California they've got 30 days in the shop to fix it or they can have it back. I would be especially agressive with a known condition.
http://caag.state.ca.us/consumers/general/lemon.htm
#15
Here is some quotes FROM a Chrysler Engineer (Bob Sheaves):
"The closer to neutral a car handles, the more quickly it is affected by road crown, etc., including ignorant drivers that are not used to less than 10 percent understeer in the suspension design. The more steeply crowned a road is, the more "pull" (which is not what is really happenning) there is to the low side. Correcting the tendency requires a change of basic geometry in the design. This is another case of ignorance being touted as "proof" of a problem." "...A "camber bolt" (added: actually an offset washer for the bolt to go through which is called an "eccentric"---RWS) is a damn sight different than a control arm. In this instance (assuming this is all that is being replaced) the bolt indicates that the net punches that put the holes in the frame brackets for the UCA to mount is off and needs to be shimmed on way or the other. Not a big deal at all." :idea:
