  • Post Photos of your car
  • Meet local members
  • Learn more about your car!
Go Back   LX Forums | Dodge Charger Challenger Magnum | SRT8 | Chrysler 300 Forum > The Knowledge Base > Articles > Engine, Trans and Exhaust
Engine, Trans and Exhaust Articles that cover installations or alterations that modify the engine, trans or exhaust. (Intakes such as CAI or K&N included)
Click for instructions on how to post an article in the Knowledge Base
Reply
Article Tools Display Modes
  #1
Old 01-29-2006, 04:20 PM
BrilliantBlackHemi's Avatar
BrilliantBlackHemi BrilliantBlackHemi is offline
Benz Owner...My Fiance Has the LX Now
Ride: 2006
BrilliantBlackHemi requires you laugh at everything they say.BrilliantBlackHemi requires you laugh at everything they say.BrilliantBlackHemi requires you laugh at everything they say.BrilliantBlackHemi requires you laugh at everything they say.BrilliantBlackHemi requires you laugh at everything they say.BrilliantBlackHemi requires you laugh at everything they say.BrilliantBlackHemi requires you laugh at everything they say.BrilliantBlackHemi requires you laugh at everything they say.BrilliantBlackHemi requires you laugh at everything they say.BrilliantBlackHemi requires you laugh at everything they say.BrilliantBlackHemi requires you laugh at everything they say.
Spark Plug Replacement 2005 5.7L *
Plug Specs:
ABout $41 for 16 new Champion RE14MCC4 Copper Plus Plugs.
Use 13 ft-lbs or 156 in-lbs to torque plugs and 105 in-lbs to torque coil bolts.
Gap plugs at .045"
Changing spark plugs:
1. Remove Engine Cover
2. Pick a coil plug set to start with. Here is the #2 (front pass side)
3: Remove the electrical connector by pushing the red locking mechanism to the left to unlock and then pressing the center catch clip while pulling up.
4. Remove the boot for the secondary plug wire:
5. Loosen the two 10mm bolts with a 10mm socket wrench.
6. Remove coil pack by pulling upwards. Make several lighter tugs to break the boot suction rather than one big pull so as to not separate the coil from the boot (breaking the unit).
7. Remove secondary plug boot. Now both spark plug holes should be exposed.
8. Use small standard (5/8" I think) spark plug socket (with rubber boot inside) and wrench to remove plug. Remove one or both at a time, it doesn't matter.
9. Inspect your plug for oil fouling, black soot and other damage. This is a good plug.
10. Gap new plug at .045" and apply liberal amounts of High Temperature Anti-seize lubricant (e.g. Napa Copper Anti-Seize). Don't skip this part. Anti-seize is needed when two disimilar metal threads are in contact (spark plug = steel, head = aluminum).
11. Install both plugs and torque to 13 ft-lbs or 156 in-lbs.
12. Install secondary coil boot and press the top to ensure a good connection.
13. Install coil and hand thread the two 10mm bolts
14. Tighten the 10mm bolts to 105 in-lbs.
15. Connect the secondary plug boot.
16. Connect the electrical connector and lock it pushing the red lock tab to the right.
17. Repeat process 7 more times.
Here's some photos of the plugs I replaced.
Old vs New (25K miles, some electrode wear as expected)
See all photos here:
http://public.fotki.com/99300mricva/...ark_plug_repl/
Took about 1.5 hours to do the job, taking my time. Plugs were in tight and squeaked when being removed at first.
Robert and Alice - Engaged 12/13/2008, NYC Central Park on "Gothic" footbridge
R.I.P. Dad aka DynoBob
  #2
Old 01-30-2006, 09:56 AM
SeadooSandi's Avatar
SeadooSandi SeadooSandi is offline
LX Jetski tower
Ride: 2007 Dodge Magnum RT
SeadooSandi .....Listen to me, I know what I'm talkin' aboutSeadooSandi .....Listen to me, I know what I'm talkin' aboutSeadooSandi .....Listen to me, I know what I'm talkin' aboutSeadooSandi .....Listen to me, I know what I'm talkin' aboutSeadooSandi .....Listen to me, I know what I'm talkin' aboutSeadooSandi .....Listen to me, I know what I'm talkin' aboutSeadooSandi .....Listen to me, I know what I'm talkin' aboutSeadooSandi .....Listen to me, I know what I'm talkin' aboutSeadooSandi .....Listen to me, I know what I'm talkin' aboutSeadooSandi .....Listen to me, I know what I'm talkin' aboutSeadooSandi .....Listen to me, I know what I'm talkin' about
Thanks for this great write-up! I'm thinking I can do this myself now instead of paying the dealer an arm and a leg.
'07 Magnum RT RWD Steel Blue with Road & Track package, NC-SXT silver honeycomb grill, 20" Foose Nitrous Chromes
Other Rides
'01 BMW Z3 2.5i Roadster
Watercrafts:
'97 Seadoo GTX - Hydroturf matting mod
'05 Crownline 202 BR with duoprop
Misc Toys
2010 Wildcat 31TS 5th Wheel
The last time I refused a beer I didn't understand the question.
  #3
Old 01-30-2006, 10:46 AM
FloridaRT's Avatar
FloridaRT FloridaRT is online now
LX Oldtimer
Ride: 2005 Dodge Magnum RT
FloridaRT is a catastrophic success!FloridaRT is a catastrophic success!FloridaRT is a catastrophic success!FloridaRT is a catastrophic success!FloridaRT is a catastrophic success!FloridaRT is a catastrophic success!FloridaRT is a catastrophic success!FloridaRT is a catastrophic success!FloridaRT is a catastrophic success!FloridaRT is a catastrophic success!FloridaRT is a catastrophic success!
Did you use Champion Plugs? What part number?
Thanks,
Bob in Florida (70 yrs young), 05' Magnum RT. Flowmaster 40's, tint windows. Danko Shaker Hood, Danko Chin Spoiler, Danko Predator Grill with Honeycomb inserts. Mud flaps & Tinted tails by Ernie 402. Version 3 rear spoiler by 402 Motoring. Superchips tuner. Honeycomb lower grills by NC-SXT. Silver Box shift kit by 351Freak.
  #4
Old 01-30-2006, 04:02 PM
krwkenny's Avatar
krwkenny krwkenny is offline
Mopar Man
krwkenny has their own own place... well, their own room... in their parents basement...
The part number is on a decal near the radiator. They are not Platinum and Dodge does not recommend Platinum on MDS engines. Mine are Champions. I just don't have the part number with me right now.
06 Brilliant Black R/T
14.1 sec. 1/4 Mile Without NOS
and before Superchips Flashpaq
Cold Air Filter
NOS Kit (occasionally)
8.5 1/8 mile 87 mph with NOS
For High Performance Parts
krwkenny@KennyRayRacing.com
  #5
Old 01-30-2006, 05:21 PM
Ride: 2006
Sorry, forgot the details on what to buy. I edited the first post to show the plug specs.
  #6
Old 02-04-2006, 07:54 PM
MrHemi2U's Avatar
MrHemi2U MrHemi2U is offline
LX Guru
Ride: 2005 Dodge Magnum RT AWD
MrHemi2U ....is Rokkin with DokkenMrHemi2U ....is Rokkin with DokkenMrHemi2U ....is Rokkin with DokkenMrHemi2U ....is Rokkin with DokkenMrHemi2U ....is Rokkin with DokkenMrHemi2U ....is Rokkin with DokkenMrHemi2U ....is Rokkin with DokkenMrHemi2U ....is Rokkin with DokkenMrHemi2U ....is Rokkin with DokkenMrHemi2U ....is Rokkin with DokkenMrHemi2U ....is Rokkin with Dokken
Quote from dealer to change plugs..$265, Joining forum $0, cost of plugs $60 (from dealer) savings $205. Took a little over an hour because I was being careful. this is a no brainer more money for mods.
Before and After
  #7
Old 02-04-2006, 08:13 PM
NC-SXT's Avatar
NC-SXT NC-SXT is offline
Makin' Grillez is my game
Ride: 2005 Dodge Magnum 3.5L V6
NC-SXT can't be humble.  Its tough being this great.NC-SXT can't be humble.  Its tough being this great.NC-SXT can't be humble.  Its tough being this great.NC-SXT can't be humble.  Its tough being this great.NC-SXT can't be humble.  Its tough being this great.NC-SXT can't be humble.  Its tough being this great.NC-SXT can't be humble.  Its tough being this great.NC-SXT can't be humble.  Its tough being this great.NC-SXT can't be humble.  Its tough being this great.NC-SXT can't be humble.  Its tough being this great.NC-SXT can't be humble.  Its tough being this great.
Step 18. Take youself out for a steak, reward for a JOB WELL DONE.
Great write up. The plugs dont look that bad. But best to change as DC says.
2009 LX and Beyond winner "BEST INTERIOR"
2010 lx and beyond 3rd place "best theme"
www.DodgeMagnumGrille.com
Custom grilles for your Magnum, Honeycomb and True SRT8 grilles for your SE,SXT or RT are our specialty.sales@dodgemagnumgrill.com
  #8
Old 02-05-2006, 09:24 AM
Beast Beast is offline
Viet Vet
Beast .......Bond. James Bond.Beast .......Bond. James Bond.
Nice job BBH, need to check my plugs when running Superchip with my Dynotech Headers. Plan to do A/F on Dyno also. Think we will be just fine.
  #9
Old 02-05-2006, 11:30 AM
Alfa Charger's Avatar
Alfa Charger Alfa Charger is offline
Alfa Charger is more friendly than Spiderman and more super than SupermanAlfa Charger is more friendly than Spiderman and more super than SupermanAlfa Charger is more friendly than Spiderman and more super than SupermanAlfa Charger is more friendly than Spiderman and more super than SupermanAlfa Charger is more friendly than Spiderman and more super than SupermanAlfa Charger is more friendly than Spiderman and more super than Superman
Quote:
I don't know where everybody is getting this "only copper core stuff". You can install any type of plug you want as long as the heat range and dimensions are the same.
The only reason "Copper cores" are instaled on the Hemis are price. Bean counters looking to save some production cash.
Even the new Champion catalog is offering metal flavors "Copper, Platinum and Iridium" for your Hemi.
2006 Dodge Charger R/T, My Winter fun car.
1987 Alfa Romeo Spider Quadrifoglio, My rest of the seasons fun car.
  #10
Old 02-05-2006, 11:42 AM
Ride: 2006
All I was saying was put back in what you took out since they are working good.
I've heard many stories about putting platinum plugs in engines not designed for it and having problems (Ford 5.0L V8, etc).
When you see the option in the catalog to get those I wonder if it's because they've been tested or just have the same thread and length specs, only the internal makeup being different.
Try the better plugs and if they work, great, but when some of them cost up to 6 dollars a piece it is an expense test when you have to buy 16 of them.
  #11
Old 02-16-2006, 11:54 AM
Quagmire's Avatar
Quagmire Quagmire is offline
Giggity, Giggity... Alllright
Quagmire doesn't look like much now, but drinking milk does wonders
Hey all,
I know this is probably a bit late, but I talked to a guy a Bosch and asked about the Platinum spark plugs for the hemi. He states that Bosch tests the plugs on actual engines before releasing the plug to the consumers. So, I have already bought the plugs and hopefully will install them this weekend. I'll leave a new post to let everyone know how they work. By the way, the Bosch platinum plugs are part number 4314 for the two point (+2) plugs @ $3.99.
  #12
Old 02-16-2006, 11:10 PM
krwkenny's Avatar
Mopar Man
Quagmire, I personally would (and did) install Copper Plugs. They are what the car was designed to operate with. Dodge informed me that none of the MDS Hemi engines use Platinum plugs.
Cold Air Filter
  #13
Old 02-16-2006, 11:51 PM
Ride: 2006
I generally agree as I put in the copper plugs. It will be interesting to see quagmire's experience down the road with the platinums.
Sponsored Links
  #14
Old 02-17-2006, 01:01 AM
bipto's Avatar
bipto bipto is online now
Enough with the whoring...
Ride: 2006 Dodge Magnum SRT8
bipto seriously needs to get a life.  I mean nobody could possibly like this guy this much in real life.bipto seriously needs to get a life.  I mean nobody could possibly like this guy this much in real life.bipto seriously needs to get a life.  I mean nobody could possibly like this guy this much in real life.bipto seriously needs to get a life.  I mean nobody could possibly like this guy this much in real life.bipto seriously needs to get a life.  I mean nobody could possibly like this guy this much in real life.bipto seriously needs to get a life.  I mean nobody could possibly like this guy this much in real life.bipto seriously needs to get a life.  I mean nobody could possibly like this guy this much in real life.bipto seriously needs to get a life.  I mean nobody could possibly like this guy this much in real life.bipto seriously needs to get a life.  I mean nobody could possibly like this guy this much in real life.bipto seriously needs to get a life.  I mean nobody could possibly like this guy this much in real life.bipto seriously needs to get a life.  I mean nobody could possibly like this guy this much in real life.
Anybody catch DCX's rationale for not recommending the Platinums? I was just wondering if there was a particular reason why they feel the platinums are ill suited for the Hemi...
Oh yeah - we got high! CLICK HERE
Brilliant Black '06 Magnum SRT8 FRI 'Street' heads, ported intake & Tomahawk cam MagnaFlow HF cats B&B cat-back B&G Stage II
The Iron Mistress Galleries
  #15
Old 02-17-2006, 07:21 AM
Fred Fred is offline
LX Guru
Fred .......Bond. James Bond.
Once again, DCX didn't use the plat plugs because they would cost more, and with the copper you'r egetting them replaced more often. Same reason for factory filling the engine with dino oil instead of synthetic.
Reply
Article Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
LX Forums Magnum Charger 300C
powered by crystaltech
