#1
Help on 114.3 vs 115
The following info is courtesy of Phatjay at dodgetalk. His company is Discount Tire Direct at 888-459-4080
"The difference between 5-114.3(4.5) and 5-115 is only .7mm, in the realm of absolute correct and incorrect. However, using 114.3 on a Magnum is wrong, but it has been and always will be done. In the past with other 115 bolt circles the 114.3 has been used. Down fall in some cases, VIBRATIONS!! Hub rings may or may not correct this. The bore of the wheel centers around the nipple that extends from the rotor, and the lug nuts purpose is only to secure the wheel to the car (if it is done correctly). When you do an after-market wheel the hub is often larger then stock so that this one wheel can be drilled to fit many different vehicles. This is the reason for the invention of the hub centric ring. The ring will size the center bore of the wheel to fit the car, allowing the lugs to do the job they were intended to do, just hold the wheel on. "
![]() ![]() ![]() http://www.watsoncard.com/magnum/ AirHammer, Heads, Sidewinder, Shorties, High Flows, Catback, Throttle Body, Predator |
#3
I wouldn't mix them. I know it can be done but I wouldn't do it to my own ride. Just my .02 worth. We put a set of 17" Primax rims on my Dad's Bonneville (also 5 on 115) and it's not even a good fit in my opinion. The rim did go on but you didn't need to be a rocket scientist to realize that something was not right.
Deuce |
#4
A quick question please. I am confused. I understood that the bolt pattern of the stock factory AWD Magnum wheels was 114.3 mm. 1. My reading of your post is that the size should be 115 mm, is that correct? 2. If yes, does this suggest that if one was in the market for another set of rims, that an aftermarket rim with 115 mm pattern would be preferable to the stock size of 114.3? 3. Phatjay suggests that vibration can result from using the wrong size. That makes sense in theory, however, I have no detectable vibration at any speed with the stock wheels and tires. Does Phatjay endeavor to explain why some other wheels vibrate with the 114.3 size, but if 115 was used there would be no vibration? Thanks in advance -- Scott |
#5
I have not seen any wheels in a 115 bolt pattern that I like. Of course, this is a taste and preference issue, but, still, nothing appeals to me. I just did a L.A. to Las Vegas round trip and had no comfort issues with regard to the front end.
His: 2006 300C SRT8 Silver Steel with All Options Plus: 275/40/20 Toyo Proxes 4's, 180 degree thermostat, Volant CAI, Mopar/Corsa Cat-back Exhaust, Centric Posi Quiet Brake Pads, Silver Star Ultra's, halogen backup bulbs Hers: 2006 Jeep Grand Cherokee SRT8 Bright Silver, with All Options Plus: Billet Lock Pins and Shifter, Rear Spoiler, Silver Star Ultra's, halogen backup bulbs, Catch-All mats, Cabin Air Filter, Wheel Locks, Centric Posi Quiet Brake Pads, Rear Seat Heaters Theirs: 2001 Mustang GT Convertible K&N FIPK, Magnaflows, Steeda Tri-Ax Shifter, Mach 1 & Cobra Trim |
#6
Well, I found Phatjay's message at Dodgetalk and the attaching diagram http://www.dodgetalk.com/forums/atta...chmentid=45955 cleared up question #3.
I'm thinking that the large center hole of the factory rim is probably machined to exactly fit the rotor. Therefore, the vehicle load is borne at the center, not on the lug nuts. So if in fact there is a slight difference between 114.3 and 115, it will not generate misalignment. I am puzzled that the factory wheel is made specially for the Magnum, yet it is 0.7 mm under-sized? Anyways, hub centric rings are designed to deal with a loose center hole on some aftermarket rims. However, they may not be specified properely, because sometimes they don't work or are misapplied, e.g. see http://www.lxforums.com/board/showth...t=centric+ring I don't know if problems with hub centric rings are unusual or not? To see diagrams of hub centric rings and some issues they address see: http://www.prestigewheel.com/Catalog/HubRings66_67.pdf So it seems that matching up of bolt pattern is not enough to insure there will be no ill-handling from after market rims. Hub centric rings might resolve a problem. Custom machining of the large center hole would certainly work. Well, that was a bit of an adventure. Still learning -- Scott P.S. Thanks Magne300 for the reply. Is your handle some kind of word play on a Cesium isotope? Last edited by Scott; 08-23-2005 at 03:42 PM. |
#7
#8
Inferno Red '05 Magnum RT AWD - Who says the AWD sits too high?! ![]() German influenced garage queen .................... German engineered daily driver |
#9
#10
maybe a machine shop can re-drill the 4 1/2" bolt circle to the correct 115mm with a slightly oversize holes and ET lug nuts, if these are the only wheels you can find that you like. Last edited by Hurst Equipped; 08-26-2005 at 08:22 PM. |
#11
#12
et lug nuts have a conical seat with a short shaft. they look like this.
http://www.prestigewheel.com/Image5392.asp Last edited by Hurst Equipped; 08-27-2005 at 12:44 PM. |
| Sponsored Links |
#13
Thanks for the clarification!!
#14
actually, i have a concern...
with 114 and hubcentric rings (metal of course :D) can i drive over 100? i don't want to be driving at a high speed then crash or have my axle break or anything bad like that...
Gary Winnick providing worldwide computer networking services. |
#15
I'm not sure where you can drive over 100mph, but if you can you won't have a high speed crash, at least not because of the wheels. Wow, I just noticed how old this thread was, brought back from the dead.
![]() 2006 Dodge Magnum R/T - SC Flashpaq, 22x9.5" American Racing Anthracite Torq Thrust M, Goodyear Eagle GT 265/35/22, Volant cat back, 14.1@98MPH 2000 Jeep Wrangler 1988 Cadillac Brougham 1966 Dodge Monaco 500 1965 Pontiac Tempest http://www.cardomain.com/ride/3250470 |
