LX Forums Modern Mopar Muscle
Serving the LX Community for 5 years. 2004-2009
  • Post Photos of your car
  • Meet local members
  • Learn more about your car!
Go Back   LX Forums Modern Mopar Muscle > The Garage > Tires, Wheels and Suspension
Discuss tires, wheels and suspension kits (lowering, etc.)
(Includes AWD and towing options)
Reply
Thread Tools Display Modes
  #1
Old 07-23-2005, 12:00 PM
RandomAccess's Avatar
RandomAccess RandomAccess is offline
What part should we make next???
Ride: 2005 Dodge Magnum RT AWD
RandomAccess is a catastrophic success!RandomAccess is a catastrophic success!RandomAccess is a catastrophic success!RandomAccess is a catastrophic success!RandomAccess is a catastrophic success!RandomAccess is a catastrophic success!RandomAccess is a catastrophic success!RandomAccess is a catastrophic success!RandomAccess is a catastrophic success!RandomAccess is a catastrophic success!RandomAccess is a catastrophic success!
Wheels & Tires - FWD vs RWD (and some other questions)
I have been shopping for Rims / Tires for the Magnum. Some sites specify FWD or RWD. What's the difference? I have AWD, so what would be best for my application
Some of the rims I like are 18X9, will these fit? what is the stock rim width?
Also, what is the lug size? 5-5" 5-5 1/2"???
2005 Magnum RT AWD, Inferno Red
AIR Hammer, Nitrous Outlet nitrous plate, ZEX 100 Shot
HHP High Flow Cats, Magnaflow cat back, KW V2
Predator, Taylor shorty plug wires
Stant 180* thermostat, ESP Mod, Royal Purple XPR
Pioneer AVIC-D1, Reverse Camera
Cel Phone Mount, leather Console cover, Katzkin Leather interior
12.571 @ 106.71
  #2
Old 07-23-2005, 03:52 PM
vsop's Avatar
vsop vsop is offline
vsop doesn't look like much now, but drinking milk does wonders
I just asked this question on another forum, basiclly FWD wheels are flat faced were as RWD are dished.
http://www.60degreev6.com/index.php?...651&highlight=
I believe the bolt pattern is 5x115, I was looking at RT rims to put on my GP, check out tirerack.com they should tell you the bolt pattern.
  #3
Old 07-23-2005, 06:11 PM
roaringmouse's Avatar
roaringmouse roaringmouse is offline
2005 300C
roaringmouse doesn't look like much now, but drinking milk does wonders
I found this on www.bigwheels.net for the 2005 Magnum R/T AWD
Bolt Pattern: 5x115
Offset Range: 34 to 42
Wheel Size Range: 18x7.5 to 22x9.5
OEM Tire Size (Front): 225/60-18 (225x727 mm)
Max Tire Dimensions: 275x752.0
http://www.bigwheels.net/?location=w..._vehicle=Dodge
  #4
Old 07-23-2005, 08:24 PM
done's Avatar
done done is online now
AWD is the only way
done requires you laugh at everything they say.done requires you laugh at everything they say.done requires you laugh at everything they say.done requires you laugh at everything they say.done requires you laugh at everything they say.done requires you laugh at everything they say.done requires you laugh at everything they say.done requires you laugh at everything they say.done requires you laugh at everything they say.done requires you laugh at everything they say.done requires you laugh at everything they say.
FWD, as the term implies, are designed for FWD cars. They generally have a larger offset, in the 40 to 45 MM range. The offset on our AWD's is 55 MM. A 45 mm offset wheel will work. The 9 inch width may not.
http://www.watsoncard.com/magnum/ AirHammer, Heads, Sidewinder, Shorties, High Flows, Catback, Throttle Body, Predator
  #5
Old 07-24-2005, 11:48 AM
Quote:
Thanks. What's the stock width?
Do you still have the stock rims on your AWD?
12.571 @ 106.71
  #6
Old 07-24-2005, 11:49 AM
So I assume I should go with RWD for the RT AWD?
12.571 @ 106.71
Sponsored Links
  #7
Old 07-24-2005, 02:44 PM
done's Avatar
AWD is the only way
Quote:
No, you would go the FWD. The RWD rims typically have offsets in the 18 to 24 mm range.
  #8
Old 07-24-2005, 09:39 PM
LowGo's Avatar
LowGo LowGo is offline
Alter ego of MyMaggieMae...
LowGo Kiss my navel,   I am up there in beansLowGo Kiss my navel,   I am up there in beansLowGo Kiss my navel,   I am up there in beansLowGo Kiss my navel,   I am up there in beansLowGo Kiss my navel,   I am up there in beansLowGo Kiss my navel,   I am up there in beansLowGo Kiss my navel,   I am up there in beansLowGo Kiss my navel,   I am up there in beansLowGo Kiss my navel,   I am up there in beansLowGo Kiss my navel,   I am up there in beansLowGo Kiss my navel,   I am up there in beans
If you're talking stock wheels, I believe they're 7.5".
I recently did a lot of research for wheels on the AWD. I put on 8.5" wide wheels with a 5 x 115 bolt pattern, +42 offset, 245mm tires. You would be fine with up to a 275mm tire with that setup. Any wider, and you'll probably need to go with a lower offset, which would probably start pushing the tire outside of the fender.
I would also recommend that you either get hub centric wheels or make sure you get the appropriate hub centric adapter to fit the wheels. Otherwise, you're centering the wheels on the bolts rather than the center bore of the wheel.
Also, make sure, when you place an order, that you let them know that they are going on an AWD Magnum and make sure that you can return them if they aren't the correct fit for the car.
Inferno Red '05 Magnum RT AWD - Who says the AWD sits too high?!
(Pictures courtesy of DannyBoy!)
  #9
Old 07-26-2005, 10:35 PM
Thanks! Exactly what I needed.
So what rim did you go with? I really want to go with a Craiger SS or Torque thrust II look. But I don't think they'll fit.
12.571 @ 106.71
  #10
Old 07-26-2005, 11:49 PM
LowGo's Avatar
I'm too lazy to retype it. Here's the link to the post I made after getting my wheels.
http://www.lxforums.com/board/showthread.php?t=14612
  #11
Old 07-27-2005, 10:40 PM
They look great. I'm inferno Red AWD also.
I think i'm gonna try to stay with the stock 18 sizing though. Where did you purchase, get a good deal?
12.571 @ 106.71
  #12
Old 07-28-2005, 12:06 AM
LowGo's Avatar
I purchased through a local tire store. I could have gotten better pricing online, but when it comes to something like wheels, I just didn't feel comfortable doing that. I like to have a live person and storefront to go to if I have problems. You still have to be careful there though, not all employees know what they're talking about... they're just trying to sell wheels!
It's good you're doing your research first. I didn't check into all the requirements before getting my first set of wheels. Got the wrong offset and bolt pattern. It was a pain, but it turned out alright.
There's nothing wrong with sticking with 18's. All the wheel requirements remain the same. Good luck in your search.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
LX Forums Magnum Charger 300C
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright LXForums.com 2004-2009
