#1
Tires and White Lettering
First off....I have an AWD RT so I know that tire and rim selections are limited. I have 9k on the car so it will still be a bit until I want to make a decision about trying to modify rims or tires, but it is never too early to start looking.
I am seriously considering white lettering or maybe even as far as white wall (unlikely) tires. I have a black mag and I have also thought about rally stripes in the future in white. I was wondering if anyone has seen this or had any tire experience trying to find white wall or white lettering tires? I am more than likely going to stick with stock rims, but was considering wider and taller tires.
Ikarus 2005 MAGNUM RT AWD 2003 MINI COOPER |
#2
IMHO- "raised whites" look good only on old muscle cars, and tacky on modern cars.
"white walls" look good on Grandpa cars (caddy's, lincoln's etc) and awsome on old school suede black "rat-rods" especially with red rims and hub caps. I understand going wider, but why would you go taller? Again these are just my 2 cents for what it's worth. |
#3
Russ ![]() - Falken 20" Explict Black rim,Falken 255 45 20 tires,8"LCD monitor headrests,12" LCD monitor in custom tri fold in back,custom made CIA,Infinity engine cover w/custom paint,custom painted centre bezel & console,custom lit cup holders, LED interior lighting & grill lites,HID's,300w sub amp w/custom enclosures,custom hand-made mesh grill |
| Sponsored Links |
#4
Try www.dbtires.com/special_interest.htm and see what they can do. I just ordered a set of 255/50/17 tires from them for my 69 Road Runner. I told them what tire I wanted, and they use vulcanization to remove the sidewall markings and put a redline on it like the original Polyglass tires of the 60s. Mine just arrived, and I haven't had a chance to even unwrap them.
They mostly do redlines, bluestreaks and wide whitewalls but they might be able to do white letters. The best thing is they can do it to any brand of tire. It's not cheap, though. Here's a Magnum they did with redlines.
![]() 69 Road Runner Convertible - 528 Hemi |
#5
Johnny Wolf -
I agree that the white walls and even white lettering is usually for older style cars, but something about the Magnum keeps making me think that the appearance of the car could almost pull it off. For the height I had hoped that the slight increase in height would provide a middle ground between 18" rims and 20" rims. I personally think that the 18" stock is a bit small, but most of the aftermarket 20"'s that I have seen tend to dominate the profile. Cdn_Magnum - Thanks for the suggestion I might try that this weekend, weather permitting. I had mostly hoped to stick with the stock rim and use a taller tire to fill some of the space without going to a large size rim or trying to lower the car. convbcuda - I am still hoping to avoid going too custom with any part of the car, and I always worry about any form of warranty in these situations. Thanks for all the input and suggestions so far!
#7
If you put larger wheels on the car you're having more of an impact than putting Diamondback tires on the car.
#8
It is not really a warranty issue so much as a consistency issue. I am a very big fan of keeping the stock look and most modifications have been done with either stock appearance or at least a consistent stock appearance in mind. The other factor is mainly avoiding spending too much on the tires. This is a daily driver so appearance is tempered with some cost considerations on things that "wear down".
#9
#15
Raised white letters look pretty good. Whitewalls = "Ick"
![]() If it looks like a duck, quacks like a duck, and walks like a duck, it probably needs a little more time on the grill.
