  • Post Photos of your car
  • Meet local members
  • Learn more about your car!
Go Back   LX Forums | Dodge Charger Challenger Magnum | SRT8 | Chrysler 300 Forum > The Garage > Engine / Intake / Exhaust / Performance
Discuss mods or enhancements to your powerplant or exhaust system.
Includes aftermarket air intakes, exhaust, etc..
Reply
Thread Tools Display Modes
  #1
Old 11-04-2008, 03:45 PM
Hemissary's Avatar
Hemissary Hemissary is online now
Spooky action at a distance...
Ride: 2005 Dodge Magnum RT
Hemissary is a catastrophic success!Hemissary is a catastrophic success!Hemissary is a catastrophic success!Hemissary is a catastrophic success!Hemissary is a catastrophic success!Hemissary is a catastrophic success!Hemissary is a catastrophic success!Hemissary is a catastrophic success!Hemissary is a catastrophic success!Hemissary is a catastrophic success!Hemissary is a catastrophic success!
Modifying the SRT8 OEM Exhaust System
After installing Kooks headers and hi-flow CAT's a few months ago, the existing Corsa CAT-back exhaust system then became too loud in my opinion. Way too brappy with a significant increase in dB (decibels) at various loads across the rpm range.
Previous to the Corsa I had installed an SRT8 OEM system, The sound quality was almost as nice as the Corsa system (different - full of base) and significantly lower dB levels...almost too quiet.
I re-acquired the SRT exhaust system in an effort to mix and match to see what I could come up with that would sound great (OK - I'm very picky) and demonstrate a reduction in dB (I'm not a kid anymore). First I tried adding the SRT resonators to the Corsa primary muffler system. Not bad, but still brappy and only a small decrease in (measured) dB.
What finally transpired was installing the entire SRT8 exhaust system, but with some very-much-needed modifications to at least be on par flow-wise as the Corsa.
Previously I had noticed that the outlets on the SRT8 suitcase muffler had a significantly smaller inside diameter (I.D.) than the rest of the entire exhaust system. Can you believe down to less than 2.1"?
The first pick shows cutting off the flange present on the left side that assists installation/removal at the factory:
This pic shows the pieces that were removed. The smaller of the three is what we actually pulled out with our fingers(!), these were what was protruding into the (major) exhaust flow, in this unit's case ~0.5"!! What this means is the exhaust gasses must back up near the inner lip to negotiate that intrusion into the existing X-pipe area. Basically two different types of restriction, interference drag by having to fight with the main exiting exhaust gasses, and a reduced outlet diameter to less than 2.2". Not good, especially the first problem.
This pic shows the actual I.D. of one on those pieces we removed by hand:
After removing part of the suitcase housing, the flange, and the inner tubing, this is what we were left with. A very nice radiused exit that we swaged up to match the outside diameter (O.D.) of the new 2.5" I.D. tubing we wished to incorporate:
After re-installing and aligning everything, a couple of lengths of 2.5" tubing were fitted. Notice also that the new 2.5" I.D. tubing enters the tail pipes (we swaged that up as well):
The end result is an even deeper exhaust note (lower frequencies) that is a little louder. Definitely not a stock SRT sound now by any means...and this is on a five-seven.
The finishing touch (after many iterations and styles) is a set of Ruf Porsche exhaust tips that fit the rear fascia's underside notches perfectly! The gap deviates less than 1/8" along the entire periphery:
Start-up clip (hope your playback system has good base):
The final result is a performance system that is now 2.5" I.D. throughout (up an appropriate 0.25" over stock), that rivals the Corsa's flow rates, sounds unique (more aggressive lower frequencies), and addresses those pesky 1st/2nd harmonics otherwise known as drone (Corsa being the only aftermarket firm to engineer-out this problem).
-----simon--------------------------------------------- Hemissary on CarDomain
  #2
Old 11-04-2008, 03:54 PM
GoofyTimL's Avatar
GoofyTimL GoofyTimL is offline
300C H.E. and MSRT8 in WV... IS Heaven!
Ride: 2007 Dodge Magnum SRT8
GoofyTimL is a catastrophic success!GoofyTimL is a catastrophic success!GoofyTimL is a catastrophic success!GoofyTimL is a catastrophic success!GoofyTimL is a catastrophic success!GoofyTimL is a catastrophic success!GoofyTimL is a catastrophic success!GoofyTimL is a catastrophic success!GoofyTimL is a catastrophic success!GoofyTimL is a catastrophic success!GoofyTimL is a catastrophic success!
I'm thinking that would be a good thing to do on the SRTs as well for a deeper note.
Still in love with my first wife, and first car ('68 Charger)... Still have the wife!
Member #4079.
  #3
Old 11-04-2008, 05:04 PM
Jaak's Avatar
Jaak Jaak is offline
Grab Life by the Ankles...
Ride: 2006 Dodge Magnum SRT8
Jaak is a modest person, with so much to be modest about.  Envy them.Jaak is a modest person, with so much to be modest about.  Envy them.Jaak is a modest person, with so much to be modest about.  Envy them.Jaak is a modest person, with so much to be modest about.  Envy them.Jaak is a modest person, with so much to be modest about.  Envy them.Jaak is a modest person, with so much to be modest about.  Envy them.Jaak is a modest person, with so much to be modest about.  Envy them.Jaak is a modest person, with so much to be modest about.  Envy them.Jaak is a modest person, with so much to be modest about.  Envy them.Jaak is a modest person, with so much to be modest about.  Envy them.Jaak is a modest person, with so much to be modest about.  Envy them.
Nice... I've found the stock SRT cat back has really held my car back. (LOL!)
11.852 @ 117.36 N/A|Heads/Mild Cam|'06 Magnum|- SRT8 -|'07 Super Bee #427|Stock Motor|12.217 @ 117.74 N/A
  #4
Old 11-04-2008, 05:21 PM
viper3ez's Avatar
viper3ez viper3ez is offline
Hello, my name is Nuvie.
viper3ez Kiss my navel,   I am up there in beansviper3ez Kiss my navel,   I am up there in beansviper3ez Kiss my navel,   I am up there in beansviper3ez Kiss my navel,   I am up there in beansviper3ez Kiss my navel,   I am up there in beansviper3ez Kiss my navel,   I am up there in beansviper3ez Kiss my navel,   I am up there in beansviper3ez Kiss my navel,   I am up there in beansviper3ez Kiss my navel,   I am up there in beansviper3ez Kiss my navel,   I am up there in beansviper3ez Kiss my navel,   I am up there in beans
nice. that's one neat butt on her that magnum
Quote:
Originally Posted by gr8crash
View Post
Its like paying $6K for your girlfriend to get a great boob job, then meeting a girl that has better boobs that are natural, are you gonna complain cuz you paid $6k for boobs for an Ex that aren't as good as the one in your hand? I think not.
  #5
Hemissary's Avatar
Quote:
Originally Posted by jaak
View Post
...makes one wonder
  #6
Old 11-04-2008, 08:44 PM
Jaak's Avatar
Quote:
Originally Posted by Hemissary
View Post
...makes one wonder
LOL, yeah, it actually does. I was looking at what you did and thought what a great way to improve an already underestimated system.
I know I underestimated it. I'm looking forward to comparing it to my SRT Corsa, which is basically a straight pipe with resonant cavities off it to create accoustic cancellations. That will be one of the things I do at the drag strip in the spring. Baseline a number of repeatable runs on the SRT system, then drop it at the track, bolt on the Corsa and do the same thing.
  #7
Old 11-04-2008, 09:03 PM
hemiuberalles's Avatar
hemiuberalles hemiuberalles is offline
hemiuberalles doesn't look like much now, but drinking milk does wonders
I don't know what a new SRT8 suitcase sells for... but you might could sell a lot of these modified and ready to install.
Detonator Yellow Challenger SRT8... 6 gears... mucho fun.
  #8
Old 11-04-2008, 10:32 PM
Hemissary's Avatar
Nice idea hemiuberalles, however the system as it comes on the LX platforms has one resonator assembly permanently attached making it rather bulky.
The reason I elected to create the thread was to demonstrate what it would take to get your local muffler shop to perform the same work.
The end-result of the above modifications is an exhaust system that flows just as well as any of the aftermarket 2.5" I.D. systems (more than enough for a 5.7), sounds "really" nice, and lo-and-behold demonstrates a similar level of drone as the stock RT exhaust system when MDS engages (read as more than acceptable). This last point is important, as essentially the only other aftermarket exhaust system that (technically) addresses MDS is Corsa (and a good job at that).
Add to the plus column is that used OEM SRT8 exhaust sytems are not too difficult to find. So for say, a couple hundred pieces of cabbage one can have the cake with icing and even eat the cherry.
Although I payed less than half for a brand new Corsa exhaust system (the one I just removed), I was loathed to pay even "that" amount for what...some frick'in metal tubes!
I sold it, spent $200CAN for the SRT system, including the mods mentioned...and feel I have just eaten the canary. I bought a Power Bond 25% underdrive pulley for $170 (they supply them to SLP BTW) with money left over...
  #9
Old 11-05-2008, 06:48 AM
stevesrt8 stevesrt8 is offline
long term car nut
stevesrt8 Kiss my navel,   I am up there in beansstevesrt8 Kiss my navel,   I am up there in beansstevesrt8 Kiss my navel,   I am up there in beansstevesrt8 Kiss my navel,   I am up there in beansstevesrt8 Kiss my navel,   I am up there in beansstevesrt8 Kiss my navel,   I am up there in beansstevesrt8 Kiss my navel,   I am up there in beansstevesrt8 Kiss my navel,   I am up there in beansstevesrt8 Kiss my navel,   I am up there in beansstevesrt8 Kiss my navel,   I am up there in beansstevesrt8 Kiss my navel,   I am up there in beans
great
great write up. Nice photos.
I quietly did this to my car over two years ago. I did not plan on modding up this car, but I spotted the suitcase "crimp" and me and my muffler man took care of it for 45 bucks.
I can't tell any difference, but it has to help on the top end of the power curve. I like the quiet cruise, and I have a nice bark when I get on it.
More than one person has asked me how the car can be so quiet!
Nothing wrong with a sleeper!
Gonna miss ya, Lou!
Steve
06 300C SRT8
option groups I, II, III
everything but DVD (no kids in my car!)
Best ET-12.794, Best trap 110.9
  #10
Old 12-27-2008, 01:12 PM
Hemissary's Avatar
I have an article somewhere(!) about the engineering firm contracted to design the exhaust systems for the 5.7/6.1, apparently a significant amount of money had to be spent to modify the exhaust note, maintain a free-flowing system, and address the significant drone generated by the 5.7 (1st/2nd harmonics).
It appears that the two systems share the same configuration/layout, except for diameter/volume increases. The above modified system with headers/hi-flow CAT's, for me, is just as satisfactory sound-wise as the Corsa...with a bit less dBm.
Quote:
Originally Posted by stevesrt8
View Post
  #11
Old 06-12-2009, 01:24 AM
willtransco's Avatar
willtransco willtransco is offline
Liberalism is a Mental Disorder
Ride: 2008 Dodge Charger RT
willtransco <<----Bow to this person!willtransco <<----Bow to this person!willtransco <<----Bow to this person!willtransco <<----Bow to this person!willtransco <<----Bow to this person!willtransco <<----Bow to this person!willtransco <<----Bow to this person!willtransco <<----Bow to this person!willtransco <<----Bow to this person!willtransco <<----Bow to this person!willtransco <<----Bow to this person!
Sweet!!..Great Info..My Complete SRT exhaust is going on shortly..good info here..Thanks !! And I think the Bee might get a little opening up as well..Cool..Thanks!
Sponsored Links
  #12
Old 06-12-2009, 09:16 AM
kaisersteiner's Avatar
kaisersteiner kaisersteiner is offline
LX Guru
Ride: 2006 Chrysler 300C SRT8
kaisersteiner IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!kaisersteiner IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!kaisersteiner IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!kaisersteiner IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!kaisersteiner IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!kaisersteiner IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!kaisersteiner IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!kaisersteiner IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!kaisersteiner IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!kaisersteiner IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!kaisersteiner IS AN LX DEITY!!!  WE ARE NOT WORTHY!!!!!!!
On my 426 I was thinking of doing the exact thing. I also was going to put a 3 inch x before the suitcase that would more gradually go into 2.75. Any thoughts on that? I have American Racing long tubes with 3 inch catted mid pipes.
Nice write up...
2006 300 SRT8... Mostly Stock "ish"
426, PPP Stage II Heads, Custom Cam, Ported Intake, American Racing Headers, Corsa cat back, Builder Bill Unlimited Shafts, Nitrous Oulet 150 Shot, Wavetrac Diff with 323 gears.
  #13
Old 06-12-2009, 11:27 AM
Hemissary's Avatar
The SRT suitcase muffler on my vehicle is, in itself, a huge perforated X-pipe within the confines of the suitcase muffler itself. I used my boroscope to explore the inside it and the resonators.
  #14
Old 06-12-2009, 12:50 PM
Cool..I was wondering if that was the case with the SRT design...hence the Great Performance..versus the 5.7 struggle with restrictions/noise abatement issues. Cool..and Thanks for this Information..Looks like I will be doing Both cars and the R/T will have a full SRT8 exhaust added.
  #15
Old 06-12-2009, 01:31 PM
Hemissary's Avatar
Actually the RT system is a similar design...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
LX Forums Magnum Charger 300C
powered by crystaltech
