#1
Tires to fit my SXT
Will these fit ok on the stock wheels: 235/65/17
http://www.tirerack.com/tires/tires....omCompare1=yes |
| Sponsored Links |
#3
Hmmm.
I though the stock tires were also 65s, maybe im just not very knowledgable on this issue. Wouldnt these tires be wider with the same height?
#5
As your tire gets wider it will also get taller(as long as your aspect ratio stays the same) in your case the 65 series.
As an example: A P2256016 and a P2355516 are roughly the same height but the P235 is wider. If you need anymore help e-mail me or PM me. I did this for a living for a long time. If I can do it anybody can. |
#7
madjeff22:
Not always. Every tire size has a range of rim sizes that it will fit on. You can usually go up one or two sizes without any problem. If the change is drastic then there exists the possibility of needing new rims to accomodate the wider tire. For handling purposes you should always try to go with the widest rim that your chosen tire size will fit onto. Deuce |
