| Serving the LX Community for 5 years. 2004-2009 |
Not a member of LXForums?
| Tires, Wheels and Suspension |
Thread Tools | Display Modes |
#16
As for the laws of science, you might want to check yourself as I have a degree in Physics from a top school just like you so try that crap on someone else.
__________________
2006 Charger SRT8 SRT Option Packages I & II Power Sunroof Eagle F1 Supercar "summer" tires Black |
#17
If you're going to include tires from different brands, sizes, types, and different conditions in the comparison, then anything is possible. In this case, a single honest answer cannot be given, one way or another, as to the size comparison of the tire contact patch. Have a nice day. |
#18
Whatever physical principles you are appealing to, they don't necessarily trump observations. The principles you cite may not be applicable because they don't take some real-world variables into account. So, what about the observations of contact patch of different width tires on glass? Scott Last edited by Scott; 09-17-2005 at 02:47 PM. |
#19
Sure, let's go with the highly scientific "tires on glass" study. I give up. You win. |
#21
255/55/18's fit fine. The control arm clearance doesn't change. The tire is just 1/4" taller in radius and 1/2" diameter, and 1.2" wider.
The extra 3" of tire width has no aerodimanic impact on a shoe box the size of a Magnum. Reset your Tire diameter for your speedo. RPM's drop slightly at the same speed. See tire size calculator. I've found no difference in MPG, just in looks. If the stock tires you're replacing are Coni self sealing, anything will be a lighter tire. That 1/2" band off goop on the inside is heavy! I'd pay more attention to load range of the tire and traction rating. I bought XL tires with a fairly high tread wear rating, and they ride significantly stiffer than the coni's did.
__________________
Adaptive Craving Control-by Hal9000 modification strictly prohibited FI IV.5, , HHP260. Inertia heads, Gibson shorties, Hi flow cats, Volant cat backs, Motorad 4127, BT Catch Can, DS tuner, Max duty Rad., Derale 32000BTU Tranny cooler with fan control, duel oil coolers, P/S cooler, SLP underdrive pulley, Pedders Track II, Hodgkiss sways, BWoody sway links, Custom brakes by TCE. |
#22
Generally i agree that tire width doesn't really make much diff, but I will say that the tread of my tires are seen much more than the stockers were originally.
I have been very pleased w/ the Kumho's I got the 255/55/18 on the stock RT rims. Price is good for a tire that I get 20k miles out of with my spitited driving habit. |
| Sponsored Links |
LXForums Message Board | Dodge Charger | Dodge Magnum | Chrysler 300 | Dodge Challenger | LXForums Message Board |
#23
I just went through this. I replaced 235/55x18 Michelin MXV4 Energy tires with 255/55x18 Michelin MXV4 Energy tires. I adjusted my speedometer/odometer with my superchips to keep the it correct. My mileage went from 24.0mpg to 21.6mpg running the same trip on the interstate that I make every weekend.
Oh, the tire pressure in both sizes was 35 psig. I then checked the 255's with 45 psig just to see if that would make a difference. It didn't make any difference. Last edited by 2005rtmag; 10-07-2009 at 09:11 PM. |
#24
If you run wider tires, how can it not effect fuel economy? I'd bet this is the reason the tires on most Chrysler produced vehicles are so narrow. Honestly, a 225 width tire on a premium/luxury car? What other reason is there? ...aside from weight. They're trying to make up for powertrain/chassis inefficiency. The findings in the post above prove this. Last edited by jg; 10-08-2009 at 09:52 AM. |
#25
Man this is painful. I will send you the extra money to cover the Lost MPG's if this thread is locked! We have to professors of science arguing over tires!
__________________
Sound clip of my Chally at idle.. http://www.youtube.com/watch?v=o1MsM...=youtube_gdata ![]() ![]() 2009 Torred SRT8 Challenger 2008 Super Bee wheels, Mopar exhaust, RDP CAI and tune, Mopar coilovers, Kooks LT's, etc Best 1/4 mile 12.84@109 11/14/09 |
#26
I would suggest comparing the frontal view of the Magnum w/ stock width tires versus the 255. I know I see alot more tire sticking out w/ the 255's. I just added the Challenger fender extensions to the Mag to cover some of it. Looks better not seeing so much tread.
#27
Here's some more reading. Wish I got paid like a scientist! from Hucho, 1998. --- Influence of the tire width on drag, lift, and yawing moment, after H Kerschbaum Fig 5.72 ![]() CD --- tire & rim size (for a 1991 BMW 318i)0.293 --- 155 R 15; 5 1/2 Jx15 St. with wheel covers 0.294 --- 165 R 15; 61 2 Jx15 St. with wheel covers 0.297 --- 175/70 R 15; 6 Jx15 St. with wheel covers 0.305 --- 185/65 R 15; 61 Jx15 St. with wheel covers 0.311 --- 205/60 R 15; 61 2 Jx15 St. with wheel covers 0.314 --- 205/60 R 15; 7 Jx15 LM 0.319 --- 225/55 R 15; 7 Jx15 LM Keep in mind the increase in Cd comes with an increase in A (frontal/projecte area) too, so you're getting a double whammy. Add to this from Phil's notes:
