LX Forums | Dodge Charger Challenger Magnum | SRT8 | Chrysler 300 Forum
Serving the LX Community for 6 years. 2004-2010
Not a member of LXForums?
  • Post Photos of your car
  • Meet local members
  • Learn more about your car!
Go Back   LX Forums | Dodge Charger Challenger Magnum | SRT8 | Chrysler 300 Forum > The Garage > Power Adders
Power Adders
Discuss nitrous, superchargers, turbos and related systems. More power!
Reply
Thread Tools Display Modes
Sponsored Links
LXForums Message Board | Dodge Charger | Dodge Magnum | Chrysler 300 | Dodge Challenger | LXForums Message Board
  #1
Old 07-22-2008, 09:31 PM
Redfox0099's Avatar
Redfox0099 Redfox0099 is offline
There is no "E" in Racing
Ride: 2006 Dodge Magnum SRT8
Redfox0099 has the wisdom of youth and the energy of age.Redfox0099 has the wisdom of youth and the energy of age.Redfox0099 has the wisdom of youth and the energy of age.Redfox0099 has the wisdom of youth and the energy of age.Redfox0099 has the wisdom of youth and the energy of age.Redfox0099 has the wisdom of youth and the energy of age.Redfox0099 has the wisdom of youth and the energy of age.Redfox0099 has the wisdom of youth and the energy of age.Redfox0099 has the wisdom of youth and the energy of age.Redfox0099 has the wisdom of youth and the energy of age.Redfox0099 has the wisdom of youth and the energy of age.
Pictorial on Installing a Labonte Motorsports Water Methanol Kit
So I have been asked to do a write up on my Water Methanol install so here it is:
Kit I got:
Start by taking the front fascia off the car:
A good place to install the pump is to the Radiator support right next to the wind shied wiper bottle especially if you plan on using the 1 gallon wiper bottle as a storage location for your water methanol (it is completely safe to use as windshield wiper fluid on your windows also because wiper fluid IS water methanol.)
Drill 4 holes in the support and mount the pump, you can mount the pump any direction but this one seemed to be best:
Run the supply line from the bottom of the wiper reservoir bottle to the pump (locate your hole in the wiper bottle below the top sensor as that is your factory installed low fluid level indicator and it will flash on your dash when you get low:
Solenoid Location on headlight support:
I ran the line from the pump to the solenoid thru the bumper to the other side of the car to protect it. From the solenoid I ran the tubing along the radiator support to the CAI:
For my vacuum line I t-ed into the hose in the front of the intake and used a size adapter to connect the hoses:
My Control box is mounted next to the brake booster under the access panel so it is out of the way and not in direct heat or water:
The RPM signal for the yellow wire is connected to a the #7 injector:
Green Pump on Indicator is located in the barrel of my RPM Gauge on the dash.
That is pretty much it, a little wiring to do since there are 4 wires going to the control box (Power, ground, RPM signal, Signal out to pump and to Solenoid).
You can get power from the cigarette lighter but be sure to put a in line fuse on your power wire.
__________________
MY ebay Store Power Ported Performance Customer Service (859) 907-6630
Redfox-Racing Website
  #2
Old 07-22-2008, 10:18 PM
USCG Charger's Avatar
USCG Charger USCG Charger is offline
Inertia 383 Stroked
Ride: 2006 Dodge Charger RT
USCG Charger requires you laugh at everything they say.USCG Charger requires you laugh at everything they say.USCG Charger requires you laugh at everything they say.USCG Charger requires you laugh at everything they say.USCG Charger requires you laugh at everything they say.USCG Charger requires you laugh at everything they say.USCG Charger requires you laugh at everything they say.USCG Charger requires you laugh at everything they say.USCG Charger requires you laugh at everything they say.USCG Charger requires you laugh at everything they say.USCG Charger requires you laugh at everything they say.
NAthan did u use the pwr from ur cigg lighter? If so can u show the in line fuse location? How does that clip tap into the wire on the #7 injector? Do I need to cut the wire to make it work?
Jason
Great write up BTW.. I'll be using it tomorrow for sure.
__________________
Inertia 383 Stroker, Duel TB CAI Paramount Performance 8.8 Rear tru trac, stage II Valvebody, flex plate, 4000 TC Nitrous Outlet 150 shot and plate Hemituner tune PLCman custom panel
  #3
Old 07-22-2008, 10:25 PM
Redfox0099's Avatar
The in line fuse in under my dash wired in line to my gauges/water-methanol kit...it is just an in line 20 amp fuse nothing special.
The clip is a T-clip, I wanted to strip back some of the wire and solder the wire on but I am having a lot of trouble with my solder gun so I didn't do it. It does not cut the wire it simply clips onto it and the spade from the other wire plugs into it...it does not damage the wire like some of the splices I have seen.
The wiring goes through the firewall up by the brake booster where the water-methanol controller is located under the access panel in the cowl, there is a place there the wires feed though.
Call me if you get stuck.
  #4
Old 07-22-2008, 10:27 PM
Inertia 383 Stroked
thx bro.
__________________
  #5
Old 07-22-2008, 10:47 PM
Redfox0099's Avatar
No Problem Coastie...I know you are slow...I made this thread with the pretty pics JUST for you.
  #6
Old 07-22-2008, 11:08 PM
SRT8U's Avatar
SRT8U SRT8U is offline
www.speedlogix.net
Ride: 2006 Dodge Charger SRT8
SRT8U <<----Bow to this person!SRT8U <<----Bow to this person!SRT8U <<----Bow to this person!SRT8U <<----Bow to this person!SRT8U <<----Bow to this person!SRT8U <<----Bow to this person!SRT8U <<----Bow to this person!SRT8U <<----Bow to this person!SRT8U <<----Bow to this person!SRT8U <<----Bow to this person!SRT8U <<----Bow to this person!
Nice write up!
Nathan, you look alot different in those pics than you do in person lol!
__________________
Kris | Mopar Specialist | Speedlogix, Inc.
2006 Charger SRT8 Vortech Supercharged by SpeedLogix
*** BMC Performance is now Speedlogix ***
Visit us online at Speedlogix.net or call 877-BMC-RWHP to talk to one of our Mopar experts!
  #7
Old 07-22-2008, 11:10 PM
Redfox0099's Avatar
..um that is K9Magnum my special helper...not me.
if you also notice those pics are from May when I 1st installed and this last weekend..you can see the intake/valve covers/coil packs are different colors
  #8
Old 07-25-2008, 09:28 AM
383HEMI's Avatar
383HEMI 383HEMI is offline
11's are Imminent
383HEMI .....Listen to me, I know what I'm talkin' about383HEMI .....Listen to me, I know what I'm talkin' about383HEMI .....Listen to me, I know what I'm talkin' about383HEMI .....Listen to me, I know what I'm talkin' about383HEMI .....Listen to me, I know what I'm talkin' about383HEMI .....Listen to me, I know what I'm talkin' about383HEMI .....Listen to me, I know what I'm talkin' about383HEMI .....Listen to me, I know what I'm talkin' about383HEMI .....Listen to me, I know what I'm talkin' about383HEMI .....Listen to me, I know what I'm talkin' about383HEMI .....Listen to me, I know what I'm talkin' about
Quote:
Originally Posted by Redfox0099
View Post
PH
__________________
422 RWHP 432 RWTQ 1.61 60' (1/8 7.70 @ 86.5) (1/4 12.25 @ 106.9) VMP Dec 1, 2007
now SCTTuned by Hemifever
First Ever N/A 5.7 Hemi Ram in the 12s (April 21, 2007 MIR)
Wifey's Car: 2008 Road & Track R/T Fully Loaded
  #9
Old 07-25-2008, 10:33 AM
Redfox0099's Avatar
PH you know this guy called me like 7 times last night.....I mean really he should of just read the directions.
He didn't even have a test light at his house or anything. jeezum.
  #10
Old 07-25-2008, 10:54 AM
ujokin2's Avatar
ujokin2 ujokin2 is offline
1st Gen III Hemi N/A into the 10's
Ride: 2007 Chrysler 300C SRT8
ujokin2 is a catastrophic success!ujokin2 is a catastrophic success!ujokin2 is a catastrophic success!ujokin2 is a catastrophic success!ujokin2 is a catastrophic success!ujokin2 is a catastrophic success!ujokin2 is a catastrophic success!ujokin2 is a catastrophic success!ujokin2 is a catastrophic success!ujokin2 is a catastrophic success!ujokin2 is a catastrophic success!
Hey I am having issues with my install ( I have DTP installing mine). No Tech signal.
Can I have them give you a ring a ding ?
__________________
Soon to be Retired -HHP/BES 426
N/A ET 10.95 @122 1ST one N/A 10Sec Club N2O 10.69@123
Joy ride TT Challenger 9.71@143
Area 51 Engine Build Phase 1
  #11
Old 07-25-2008, 11:22 AM
leveil22's Avatar
leveil22 leveil22 is offline
Leveil24
Ride: 2006 Dodge Charger 3.5L V6
leveil22 is more friendly than Spiderman and more super than Supermanleveil22 is more friendly than Spiderman and more super than Supermanleveil22 is more friendly than Spiderman and more super than Supermanleveil22 is more friendly than Spiderman and more super than Supermanleveil22 is more friendly than Spiderman and more super than Supermanleveil22 is more friendly than Spiderman and more super than Superman
wonder why my snow kit not that easy
__________________
The Boss : Supercharged 3.5 V6 too many mods to list just have to see it person.Member ACLX Club as you can see we don't play around out here.!Update! Soon to be loaded with Inertia Racing Heads and Cams! AE Carbon ported lower intake and TB!(Installed) !New Dual Sunroofs! (check out my post)
  #12
Old 07-25-2008, 11:52 AM
Redfox0099's Avatar
Quote:
Originally Posted by ujokin2
View Post
I got the TACH signal from here:
If they can't figure it out have them call me.
  #13
Old 09-17-2008, 07:06 PM
leveil22's Avatar
Leveil24
so will mine be the 5th injector?
__________________
  #14
Old 09-17-2008, 08:00 PM
Redfox0099's Avatar
You can get the signal from any injector...I just picked the 7th cylinder.
  #15
Old 09-18-2008, 04:39 PM
monty1269's Avatar
monty1269 monty1269 is online now
Mike<---LXForum addict.
Ride: 2005 Dodge Magnum RT
monty1269 can't be humble.  Its tough being this great.monty1269 can't be humble.  Its tough being this great.monty1269 can't be humble.  Its tough being this great.monty1269 can't be humble.  Its tough being this great.monty1269 can't be humble.  Its tough being this great.monty1269 can't be humble.  Its tough being this great.monty1269 can't be humble.  Its tough being this great.monty1269 can't be humble.  Its tough being this great.monty1269 can't be humble.  Its tough being this great.monty1269 can't be humble.  Its tough being this great.monty1269 can't be humble.  Its tough being this great.
Hey LOOK! A write-up!
__________________
SRT headers- SRT Magnaflow hi-flow cats-SLP Loudmouth II, Billet Tech Goodies EVERYWHERE Diablo tuned!! Inertia SPARTAN CAM 214/218, 113 LSA, 3.06 gears, Edge 3200 TC, 17 X 8.5 Borbet TS w/ 275/40 Hoosiers : Hemi Registry 0436
Best 60'= 1.896 (stock TC and gear) ET= 12.841
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
LX Forums Magnum Charger 300C
powered by crystaltech
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright LXForums.com 2004-2010
