Results 1 to 13 of 13
Thread: Tire Safety ?
    Jun 2005
    Phoenix, AZ.
    Tire Safety ?
    What's the safety point (speed rating) on a V rated tire if you have to have a patch for an extremely slow leak caused be a very small flat nail?
    Jun 2005
    Phoenix, AZ.
    Doesn't anybody have an answer for me. I need to know how fast I can go still without having any safety issues.
    Nov 2005
    Phoenix, AZ
    Honestly, I would keep it under 55 until you can get a new tire. :(
    Jan 2006
    The speed rating is for a unmolested factory tire. A small nail hole with a patch inside the tire should not be an issue for most driving.
    If you are driving over 120 MPH for long periods you might consider a new tire. Driving 80 MPH on the interstate for long periods should not cause too much concern.
    Enjoy life- you only get one!!
    Jun 2005
    Phoenix, AZ.
    Thanks Chris, I don't think I can do that unless my foot looses a lot of weight.
    Quote Originally Posted by FactoryD View Post
    Arizona
    So long as it is repaired correctly you shouldnt have any issues unless you are pushing it to the max. In the military we repaired our own tires . First we plugged the hole , then we ground out an area so the patch would sit almost flush inside it. Granted these werent high speed tires , but we have had the Hummers well over 80 MPH with no issues.
    Since I have a V6 I dont have the issues with top speed you do , lol.
    ~Gary
    -2005 Dodge Magnum RT-
    -2016 Jeep JK Unlimited Rubicon-
    This is the one I should have had years ago. Man is it a blast to drive !!
    -2006 Dodge Magnum SXT - (Deceased)
    Jun 2005
    Phoenix, AZ.
    Ok, so you think I'm safe for stretches between 70 & 90 with an occasional burst to 110ish on occasion (til I replace). The tire shop guy told me because it is a V rated tire he did not drill out the hole to save some of the speed rating. He told me not to go over 140 (not a problem with a stock RT anyway).
    Quote Originally Posted by Shelby View Post
    Nov 2005
    Phoenix, AZ
    Quote Originally Posted by Brilliant R/T View Post
    LOL. I hear ya Joel. I totally agree with everyone. The only reason I say that is because a blow out can be a very dangerous thing to happen and I don't want to be the one that told you it would be cool.
    Jun 2005
    Phoenix, AZ.
    I knew you cared. LOL
    Arizona
    He loves ya man .... now give him a Budweiser !
    Feb 2004
    Seattle, WA
    With a properly repaired tire (at a good tireshop), I don't think you will have a problem 70-90 with a blast to 110 once in awhile.
    The risk *IS* higher for a blowout, can't deny that.... but I, Personally, would have no problem with it in my ride.
    2012 Ram 1500 Express - 4x4 - HEMI - Black
    1966 Dodge Charger - ???? - ????
    Experience is that marvelous thing that enables you to recognize a mistake when you make it again - Franklin P. Jones
    Insanity: doing the same thing over and over again and expecting different results. - Albert Einstein
    Mar 2006
    where the heart is
    The actual rule of thumb is, you loose 1 speed rating for every repair up to 2, after the second repair, it drops to a S speed rating(102 mph) so if you have a V rated tire, it is now an H(130 mph)...and that's only if the tire was repaired using tire industry standards...
    Previously: "Vanessa" 2006 Charger R/T with all kinds of little details and a unique red bee stripe...
    Currently: "Maleficent" 2006 300 SRT8 option groupII, rear seat VES, Kicker stereo upgrade... 86K
    Future: 2015 Charger SRT Hellcat( late availability!)
    Jun 2005
    Phoenix, AZ.
    Thanks Eric for the re-assurance. So I will assume I now have a H rated tire (1 repair with patch only, no plug, not drilled out to make the hole larger).
    Quote Originally Posted by CHARGERSHED View Post
