Results 1 to 15 of 17
    Kenner,Louisiana
    how to wire new LED tail lights
    I got a new set of LED tail lights. Only the top portion looks to be LED. There is an unusual wire on the new tails. Need help how to install. NO directions came with them.
    '07 Charger R/T
    MODS:
    Diablosport Predator -JBA Catless Exhaust - Airhammer - B.T. Embelms -SRT Grill - Pedders Lowering Springs - 180 T-stat - RK Sport Hood - SRT Headers
    Guest Guest
    Kenner,Louisiana
    ok im slow... the wire that came on the new tail looks to plug into somthing. Im not changing all the lights to LEDS only the top ones [ that had the wire comming out of it ]
    Jan 2007
    Las Vegas, Nevada
    That looks like the pigtail on my Eagle Eyes tails. Pull the lights out of the old tail light. Remove the brake light bulb and plug that pigtail into it. You have to push a little harder than feels natural...at least I had to. Make sure the light lights up. If not, take the pigtail back out, flip it upside down and put it back in. Your polarity might be backwards.
    Post some pics when you get it working!
    What happens in Vegas stays in Vegas...unless you have to go to a clinic to get rid of it.
    Kenner,Louisiana
    bump
    Lynchburg, VA
    Yes that plug, plugs into where your top light bulb of the stock lights go. Take the bulb out and plug that in.
    Tinted glass, Cut front springs 1 1/4",
    AirHammer HO, Duel Flowmaster 40s, De-molded,
    Sonar LED Tails, Flat black honeycomb grille,
    18" RT wheels & 245/45, No ESP Mod, Predator,
    Innovate WB A/F guage, Ported Lower Intake, upgraded front brakes
    to the larger RT rotors and calipers.
    Oct 2004
    Las Vegas, NV
    It just goes into the stock tailight socket, if it doesn't work, like mine didn't at first, turn it around and it should work.
    Jan 2007
    Las Vegas, Nevada
    The top light is stock, the bottom is aftermarket and looks like it has the same pigtail you have shown, right? The stock brake light bulb pulls right out of its socket, and that pigtail goes into it. Once it's connected, test it by hitting the brakes or turning on the lights. If it doesn't work, take the pigtail back out and flip it around. Test it again. The wires attached to the pigtails get pushed back into the tail lamp housing and it the light sockets go into the new tail light just like it were stock.
    Does that make any better sense? I wish I had pictures from where I did mine. This photo is actually from the KB.
    Kenner,Louisiana
    ok i think i got it. you guys kick aZZ
    Jan 2007
    Las Vegas, Nevada
    So where are the pics with the installed lights?????
    C'mon man! You're keeping us in suspense!
    San Marcos, CA
    Quote Originally Posted by LasVegasMagnum View Post
    So i had these lights for a bit and I thought of this when installing what if a led burns out yup they are sealed inside the light do you break them apart and hope to get them back together???? well it happened had about four burn out in one tail so what did I do...........tinted my stock tails!
    Air Bags for people that understand the difference!
    Kenner,Louisiana
    Kenner,Louisiana
    Kenner,Louisiana
    Kenner,Louisiana
