Results 1 to 15 of 21
    Minnesota
    Average oil pressure on the 5.7L Hemi?
    I took a look on my Evic today and was really surprised to find how low it was.
    - At idle right around 20 psi
    - cruising psi in the 40's
    - WOT psi in the 50's
    Seemed low to me, I guess I am use to my 3800 where oil pressure is in the high 40's low 50's psi at idle.
    So what is average oil pressure in these motors?
    2006 Charger R/T NA 1/4 mile PB: 11.741 @ 115.91 mph on a 1.606 60'1998 C5 corvette coupe NA 1/4 mile PB: 11.778 @ 118.38mph on a 1.763 60' nitrous times to come
    JonzMgnm's Avatar
    JonzMgnm is offline Just a squirrel, trying to get a nut....
    Jan 2006
    Commack, New York
    Those #'s are normal for the Hemi.
    What viscosity oil are you using?
    John Y
    382 RWHP / 411 RWTQ 12.25@110.46MPH
    HEMI REGISTRY #426 DYNO VIDEO DYNO SHEET!
    Jun 2006
    Houston, TX
    yep, those are normal pressures.
    silver steel metallic charger r/t...gone but not forgotten!
    2012 Charger SRT8...B&B exhaust...CAI
    Minnesota
    Quote Originally Posted by JonzMgnm View Post
    5W20 in the charger
    5w30 in the monte
    They must have alot of clearance on the bearings from the factory I take it?
    Feb 2007
    Michigan
    Sounds OK. Mine runs about 20 PSI hot at idle and 50 cruising.
    Rule of thumb is 10 PSI / 1000 RPM. Too much oil pressure is bad too.
    Mike
    06 Magnum R/T Midnight Blue
    Inertia Motorsports Heads decked .030 (10.3 CR), FRI Hellfire cam, AirHammer, JBA Headers, JBA Mids, JBA Cat-back, Diablo Predator, 6.1 Injectors and rails, ZEX N2O Kit, Nitrous Outlet N2O plate,180* T-Stat, DashHawk, Police Package oil cooler
    11.89 @ 116.94, 1.99 60', stock converter and tires http://i162.photobucket.com/albums/t...m/SCAN0007.jpg
    Feb 2007
    Rochester, NY
    Uh oh!
    I just learned today how to get into the EVIC service menu... and my oil pressure was at 53 at idle. (I used a K&N Gold oil filter and 5W20 oil, in case you need to know)
    What should I do?
    JonzMgnm's Avatar
    Jan 2006
    Commack, New York
    Quote Originally Posted by shuboney View Post
    Uh oh!
    What should I do?
    At idle at operating temperature you should be around 20-25 psi.
    Feb 2007
    Rochester, NY
    Right.
    Like I said, what should I do?
    Is this a serious problem that the dealer should look at? The oil level indicator on the dipstick reads "normal".
    JonzMgnm's Avatar
    Jan 2006
    Commack, New York
    Right.
    I don't want to insult anybody's intelligence, but I don't want you to have a problem with your ride either.
    1. Always check oil level with the car on a level surface with the engine shut down at least 5-10 minutes to allow proper 'drain-back' of the oil.
    2. The oil pressure will vary with temperature so try to check the pressure when the car is up to operating temperature.
    If you have done these then something is wrong if your oil pressure is 53 psi at idle and operating temperature.
    Jun 2005
    North Carolina
    What is your pressure at crusing RPM (@ 1500 - 2000) ?
    Displaced Hokie
    2005 Dodge Magnum R/T
    Jun 2010
    Is there an easy way to check the oil pressure if your car does not have an EVIC? I got the dreaded oil pressure light the other day and the 0520 code. My mechanic said he didn't have a way to hardline into to check the pressure.
    Calgary, Alberta
    The key here is "at operating temperature".
    It can be as low as 4psi @ idle and from 25 to 110psi @ 3000rpm. Typical is 15-25psi @ idle, 50-70psi at 3000rpm. The Service Manual is a wonderful tool.
    near springfield missouri
    Thread from the dead!!!!! Lol
    [SIGPIC][/SIGPIC]
    6.08 l magnum R/T
    371 PWR stroker, 13.8.1 compression, E85,Thitek Heads.
    My new build!!! Thanks to Kent Irwin
    http://www.pwrparts.com/
    Tuning By Mike at
    http://www.ostdyno.com/
    Calgary, Alberta
    Yipes; so it is...
    Quote Originally Posted by d794402000 View Post
    The oil pressure sending unit just above the oil filter is removed, and an analog gauge is employed, that's the procedure...
    Sep 2014
    My oil light came on, threw a cell P0520...I checked my evic at NOT and it went as low as 8psi, bad oil pressure sensor I'm hoping....
