Results 1 to 4 of 4
    Sep 2010
    USA
    FS: Roe Supercharger and Upgraded Methanol Kit
    Description: Selling my Roe Racing supercharger and some extra pieces. I would like to sell this as a complete kit so I won't be parting it out right now but that may be a possibility later if it doesn't sell as a kit. This is an early model that uses the 3.3L Lysholm head unit and has a 6lb pulley. It has been converted from the VEC to and SCT tuner. The lower manifold, manifold plate, and intake plenum have all been powdercoated wrinkle black. Come with a Roe Racing throttle body that I had Sean modify with two methanol ports on the bottom behind the throttle blade. Heat shield is a custom piece from Justin and is a combination radiator cover/heat shield all in one. Methanol tank is another creation by Justin and mounts using factory mounting points where the spare battery panel sits. Tank has built in mounts for the pump and controllers. The bottom bolt for the pump mount is broken so it will need to have another stud welded on to repair it. If I get the full asking price I will have Justin repair this and powdercoat it again. The methanol kit uses the original pump that came with the supercharger kit but has a Snow Performance controller, flow monitor, anti-siphon solenoid and a bypass safety solenoid. The methanol is setup to come on under boost and if the system runs out of methanol it opens the bypass safety solenoid and bleeds off boost to prevent engine damage. Everything is stainless steel braided lines and black anodized fittings. This setup made 580rwhp on my 05 QC. Asking $4800 for everything.
    Price (USD): $4800
    Shipping & Pickup: Can Meet / Pick Up in person, Can ship within Country
    Shipping Cost (USD): $00
    Sep 2010
    USA
    Bump
    Apr 2006
    Houston, TX
    I was confused as to what the supercharger was for, so I looked it up. Hadn't ever heard of it. So its for a Viper correct? Pictures of it may help also.
    2009 Stone White Challenger R/T 6-Speed
    D1 w/ Stage 2 Intercooler||180 Jet Tstat||85mm ported throttle body||Petty's Garage Strut Brace
    ARH Longtubes||Corsa Sport Exhaust||Diablotoona email tune
    Sep 2010
    USA
    Quote Originally Posted by Big RobsR/T View Post
    yes, its for Viper
