Results 1 to 12 of 12
Thread: I smell coolant
    Jul 2012
    Sulzbach-Rosenberg
    I smell coolant
    Ok, maybe I can get some insight/help here. Everytime I drive my car and park I smell coolant. Took it to the dealer, they checked the engine bay, even lifted it and found there is a small leak somewhere but they can't find the damn thing. I have already changed my water pump, thermostat, and lower hose. Besides the fact that I can smell the coolant, I have a killer glass hose also and can see when its low. The shop did a compression check but couldn't find the leak. They told me to leave the car over night, let it cool down and they would do another compression check in the morning. Has this happened to anyone else here, and if so what the FUDGE was the problem? Better yet, anyone have an idea where the leak can be coming from?
    Thanks dmcphailtx thanked for this post
    Likes dmcphailtx liked this post
    Nov 2013
    South Florida
    Check the endtanks on the radiator, hard to see but a common place for a leak.
    2006 300c SRT8
    PWR Ported Heads | SRT Max Cam | 3.55 Getrag | GTP Ported Intake Manifold | Kooks Longtubes | Corsa Sport / SRT Resonators | AMG 8 Piston Brake Calipers | Hemituner 6,800 TCM | BT Catch Can | LMI True CAI V2 | Tranzformer | MM 87mm TB | Johan Tuned | REM Adjustable Endlinks & Front/Rear Shock Braces | 33/22mm Front/Rear Sway Bars | Michelin Pilot Super Sport 295/35/20 & 245/45/20 | 10" Widened Oem Wheels | LC-2 Wideband Analog Output to Trinity |
    Thanks unfall66 thanked for this post
    Nov 2015
    Georgia
    I have and none of the dealers can find it. Replaced radiator already. One dealer smelled it when I took it in but said they couldn't replicate the smell wheh the techs were working on it the next day!
    Sent from my SAMSUNG-SM-G930A using Scat Pack Forums mobile app
    Nov 2010
    Lower hose. It collapses when it gets hot. Check and replace
    Sent from my iPhone using Tapatalk
    Jul 2012
    Sulzbach-Rosenberg
    Just had the lower hose replaced last month, still got that freaking smell. This sucks, I have to keep coolant in my car all the damn time.
    May 2015
    Louisiana
    Agree on the radiator end tanks, where they meet the main tank there is often seepage or a leak. Could also just be a small hole in main radiator or hopefully not, the heater core.
    Sent from my SM-N920T using Tapatalk
    2016 Challenger SRT 392, A8, Technology Group
    Feb 2012
    Orland Park IL
    if you smell it inside in might be the heater. If that's the case you'll smell it for a while, until it really starts leaking an you'll get a puddle.
    bill
    2007 BB Charger SRT8
    Airaid CAI, 180 Tstat, BT Catch Can, D1S HID headlight conversion, red led interior swap, Magnaflow cat back exhaust, MTCM, 3.73 getrag, six speed motor mounts, Lakewood 70/30 front shocks w/ V6 springs and 50/50s in back, SRT Max Plus, Paramount 55series Nag1 and torque converter, CTP solid cradle bushings
    285/35 R20 Michelin Pilot Supersports all 4 wheels
    28" hoosier slicks, MH racemaster skinnies.
    Tuned by Tim @ MPH. 403 RWHP, 402 TQ.
    12.133@111.42, 1.762 60' 620 DA
    Jul 2012
    Sulzbach-Rosenberg
    Well as it is, I park my car, get out, and the smell hits me. One time at a car show I was reving the engine a bit, next thing I have a puddle coming from under my car. That was FREAKING embarrassing.
    May 2015
    Louisiana
    Ok well that's definitely not the heater core. Just gotta keep looking, it's aggravating I know!
    Dec 2016
    I get the smell on occasion. Most of time during warmer months.
    I can it find a leak anywhere. I have found just a few drops coming out of the coolant tank overflow hosed dripping down the inner fender well. Car has never been over 217 degrees. Never noticed it until after timing set was changed for a recall.
    Nov 2010
    Have you added dye yet?
    Nov 2010
    Maybe read this article and see if anything is relevant
    http://www.speedysgarage.net/challen...tem_rapair.htm
