Results 1 to 13 of 13
    Jan 2006
    Las Cruces, New Mexico
    Lights out on Instrument Cluster Gauges
    The gauges in my '06 MSRT8 work. The lights do not work suddenly. I've checked the dimmer switch to make sure that wasn't it.
    Is there anything else I can check easily? I'll be hooking up the Diablo Tuner to read codes the first chance I get.
    Anyone else have their gauge cluster lights go out suddenly? My gauge cluster went bad before when it was under warranty. (I never saw a problem with it...the dealership said that it was going bad based on a test they did and got me a new one.) Now I'm out of warranty. :/
    Did the radiator cap mod: SRT8 is here....
    The Hemi says, "VROOOM!" Hemi Registry #00420
    May 2009
    Edmonton Alberta
    check all of your fuses from under the hood and on the back under the false floor..
    Dec 2007
    City of Riverside, California
    That is an EL sheet, powered by a power inverter (DC/AC). No bulbs in the cluster. The sheet plugs into a connector on the internal circuit card. The panel lamps driver pins are: C3 11+ and C1 2 Ground.
    If you have intermittent panel lights, you might have a cold solder joint at either the connectors, the inverter, or the connector for the EL sheet.
    You would have to tear into the cluster to check any of these connections, but this info might help, if you need to.
    I spend my time modding your lights and developing new products, not being your FaceBook friend.
    http://www.luxte.ch
    Lux Technologies
    Mar 2013
    Any body else ever have this problem? I just started my 06SRT8 Charrger today after a week of sitting int he garage and my cluster lights do not work. all the gauges work fine and are accurate but no gauge lights. I checked the dimmer switch and that works fine.
    Tried finding a answer to this can cant really find one except for the above one but that is way over my head in terms of technical language. is there a simpler way of putting it?
    Dec 2007
    I have an old cluster. I'll post pix, later
    Mar 2013
    Quote Originally Posted by diboblo View Post
    So i need a new cluster? or are you saying you will be able to take photos of what i need to do?
    Thanks for the help either way.
    Dec 2007
    Odd as it sounds, try unplugging all three connectors at the back of the cluster & plugging them back in. Also. Try doing the same with the headlight switch.
    It's PROBABLY the headlight switch.
    I have a loaner I can send you.
    A cluster is more than $500. A headlight switch is cheap.
    Mar 2013
    Okay i will attempt to look at it tonight. Never taken the cluster out of this car before so need to figure out how to do that first. The headlight switch i dont imagine would be that difficult so i may try unplugging and plugging that one back in first.
    Dec 2007
    YouTube search will get you how to videos on both.
    Mar 2013
    Yep found one and looks like 8 screews and hopefully just plugging stuff back in better. Crossing my fingers.
    Mar 2013
    Went to drive home Saturday from work and the lights worked. So i am guessing its a loose conection. Didnt have time to look at it this weekend but at least i have an idea now. Thanks
    Dec 2011
    Oshawa, Ontario
    I had the same issue, switched out the headlight switch and problem solved. Was a cheap fix and took all of 5 min. Worth a shot before you tear into the cluster.
    Current: 2012 Dodge Charger SRT8-Pitch Black----Solo Mach X3/InTune/K&N/BT.......
    Previous:2006 Dodge Charger Daytona-Go Mango
    Dec 2007
    Headlight switch, for sure.
