Results 1 to 4 of 4
    Oct 2010
    Laurel,MS
    how to read transmission dipstick?
    Bought a transmission dipstick today M 7226. Can't figure out how to read it. There's a 25 degree and 80 degree points on it. How do I use this comparing it to the fill chart? 80mm is past the pastic part of the dipstick
    Aug 2004
    Ocala, Florida :-)
    The markings at the end of the dipstick aren't degrees - they are markings in mm (millimeters).
    You need to get the level reading from the dipstick, then use a laser thermometer to see the temp of the oil.
    Then you take these two figures and compare them to a chart for transmission oil level to see if your tranny has the corresct amount of oil.
    Oct 2010
    Laurel,MS
    Bought the Assenmacher M-7226 722.6 Trans Dipstick. Suppose to be comparable to MB #140 589 15 21 00. The indicator is different than the one in the picture.
    wvsrt8's Avatar
    wvsrt8 is offline shiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiit!
    Oct 2011
    drive the car until fluid is hot...................20 miles lets say...................level should be in the range for 80 degrees celcius.
    2007 MSRT8
