Results 1 to 12 of 12
    Dec 2009
    Vancouver b.c.
    rear nivomat upper shock mounts
    Would rear nivomat upper shock mounts prevent my car from lowering? I already have koni str's and eibach pro-kit springs.
    Big Ole TEXAS
    No. I have the same setup on my 06 Daytona which had Nivos. The car lowered just fine.
    Mar 2010
    How do you like the ebachi springs compared to the MS1 springs? I sent you a PM to get more info
    Dec 2009
    Vancouver b.c.
    Quote Originally Posted by ethanhunter View Post
    pm sent
    Dec 2009
    Vancouver b.c.
    Can anybody else that swapped nivo's for koni shocks chime in?
    Feb 2006
    Columbia Ridge, OR
    Quote Originally Posted by rockpolisher View Post
    There is no such thing as a "rear nivomat upper shock mount", all rear shock mounting is the same.
    Well, the Mayans and other Soothsayers were right, the end has begun.
    Common sense is so rare it should be considered a superpower
    Dec 2009
    Vancouver b.c.
    Actually, there are 2 different kinds of rear upper shock mounts.
    Here is the nivomat rear upper shock mount:
    And here is the non nivomat one:
    Dec 2009
    Vancouver b.c.
    Anybody know if the nivomat rear upper shock mount will prevent me from getting the full drop if i have koni str's and eibach pro-kit? I still have about a 3 finger gap between the top of the tire and the fender.
    Jun 2009
    Anaheim, CA
    Quote Originally Posted by Big Boy View Post
    Yes there are two different upper shock mounts. The mount for the Nivomat is mostly rubber with a flat plate and the standard shock has a rubber bushing placed into a contoured plate.
    See pic below. Standard shock mount on the left and Nivomat mount (missing theplate) on the right.
    Will the Nivomat shock mount on a Koni shock cause you to not be able to lower your car..... No. That has to do with the springs and not the shock mount.
    Now in looking at the pictures I posted above, you can see the the mounting location of the shock mount, that the Nivomat shock mount does not quite sit a slow as the standard shock mount. This may play into the actual end result height that you were able to get out of the springs.
    Did your car get any lower with the springs you put in? If so, how much?
    I would suggest purchasing the standard shock mounts and try those. As long as your springs, shocks and bushings are all in correectly, then you should be ok.
    Need a tire calculator? Use this one.
    Plenty more pics on my Facebook page
    Dec 2009
    Vancouver b.c.
    Ok thanks fnkycld, i'll try the standard mounts and report back. I'm just baffled cuz when i look at pictures of others with the same suspension combo and wheels and tires, it seems like mine sits higher up in the rear. I went from mopar stage 1 springs with bilstein hd shocks/struts to eibach pro-kit springs with koni str shocks/struts. Add that up and i could've and should've gotten coil-overs!
    Big Ole TEXAS
    I used the Nivo mounts when I installed my Koni/Eibach setup. No problems and car sat even. I then got the clunk in the rear (it's been posted on several threads) and I started replacing parts. Lastly I swapped the mounts (non Nivo ) and used a nylon shim. Car still sits the same and does not clunk.
    Mar 2008
    It's the Nivomat shock itself that will prevent the drop, not the shock mount. I used my Nivomat mounts on Eibach Prodampers back when I had them and it worked out fine. You shouldn't have any problems.
    PPP stage 3 big valve heads, Howards cam 219/227 .600/.575 112 +4, MMPG stage 1+ ported 6.1 intake & 85mm throttle body, LMI 4" true CAI, MSD "Blaster" coils, JBA headers & mids, Corsa exhaust, Paramount series 55 transmission, "Dominator" torque converter & stage 2 valve body, KW V2 coilovers, Eibach sways, BWoody links, Razorsedge brace, 226mm Getrag 3.91 LSD, Wilwood "plus 2" big brake kit by TCE, tuning by Robert Dito of Ditos motors
