Results 1 to 9 of 9
    Feb 2008
    Langley B.C. ....2007 CHARGER SRT8
    Differential oil...what weight?
    Hi all...
    Looking at changing the diff oil in a 2005 Magnum AWD... what is the recommended weight and do you HAVE to use a Mop
    ar brand? If not, any suggestions on brands.
    Thanks in advance...
    The Rocket - Made in Canada....
    Jul 2011
    calgary, alberta
    differen't weights between front and rear diff, also I used royal purple. They say diff fluid will last the life of your vehicle but I wanted mine changed anyway.
    Mar 2009
    Edmonds, WA
    Rear is 75-140 and front is 75-90 as I remember. Front says fill for life, but I changed mine-takes about 1 qt. Rear needs 1.7 qts. I have usually done Mobil 1 in rear, but last time could only find Royal Purple in correct weight.
    Sent from my SCH-I405 using Tapatalk
    Mar 2009
    Edmonds, WA
    Also, front has no drain and my siphon tube was too thick, so I used Slim's compressor powered brake bleeder and it sucked it out like a champ! The front diff plug is also a major PITA to get loose
    CT
    make sure you get straight oil as well since you don't have a LSD in the rear. Most stores are carrying Limited Slip additive fluids only these days so look for LS on the bottle and skip it if it does. Stock difs are open and don't need any friction modifier crap in them.
    Bone stock time: 12.832 @ 108.51 with a 2.033 60ft... On GY F1's Full Weight
    Predator and C&L Intake: 12.386 @ 111.78 1.868 60ft On GY F1's Full Weight
    Current mods: Hi-Flows, 180. Volant, PS Cooler, Trans Cooler, SS Brake Lines, B&B exhaust.
    Pedders Track II Extreme, Wavetrac, Moroso oil pan/catch can, 6.1 MTCM, Mopar trailer hitch.
    Dec 2004
    maine usa
    The Mopar lubes are top notch. No worries if you can't find Royal Purple or Mobil One.
    Aug 2010
    McDonough, Georgia
    Do the SRTs need the firction modifier added to them or do their rear ends have a different set up?
    TRINITY 93 CAI tune. Volant CAI. Custom Dynomax Ultra Flo exhaust sytem. Billet Technologies Oil Catch Can, washer cap & shifter plate. Drake Strut Tower Brace. 3 G Customz Right Side Cover & HEMI Half Covers. AMG Paddle Shifters.
    Nov 2009
    Flint, Michigan
    i have some ls fluid hanging out already, is it ok to use? i do not have an lsd
    '06 INFERNO RED SRT-8 OPTION GROUPS I,II,III
    MODS -KOOKS LT's w/HIGHFLOW CATS, JBA FULL 3 INCH CATBACK, PRO TORQUE 2800, SHR CMG-1 CAMSHAFT, PAC RACING VALVE SPRINGS, 12000K HIDs IN PROJECTER HEADLIGHTS, 12000K FOGS, R1 CONCEPTS DRILLED AND SLOTTED ROTORS, CUSTOM GAUGE CLUSTER, CCW 505a WHEELS, NITTO NT05 275/40 ON THE FRONT AND NITTO NT05R 315/35s ON THE REAR, SHR VIKING, D1SC STAGE 2, 3.55 RICHMAND GEARS, SLP LINE LOCK, TUNED BY EPG 3 AT SOUTHERN HOTROD.
    CT
    Quote Originally Posted by Jd3443pd View Post
    depends on the year. First gen LX's have an open differential and you should not be using a friction modifier. Only with the introduction of the getrag LSD in later years was it needed, so first gen SRT's are a NO for reference. Most aftermarket options are gear based and should not be using an friction modifier either as that is used only in clutch based LSD's.
