Results 1 to 15 of 20
    Nov 2009
    Richmond Hill, Ontario Canada
    problem fitting 275/40/20 on SRT8. Need advice.
    Well, - today I went to the local store to get my new 275/40/20 General Tire Gmax AS-3 tires for my 2010 Charger SRT-8. The car is totally stock. To my surprise, they did NOT fit in the front. They were clearly rubbing what appears to be a control bar, when turned.
    I did read that many tried 275/40/20 size tire in the front on the same car with no issues and, in fact, this size came recommended. So, now I am at a loss as to what gives? The tires did fit in the rear just fine.
    The question is, - what to do at this point, - should I forgo on 275/40/20 and go with 255/45/20 all around? is there anything else I should look at in order to solve this somehow?
    Aug 2009
    MASS
    Get a small spacer, probably 3 to 5mm it's the cheapest solution
    Apr 2010
    Chicago,IL
    Spacer will clear it,or shaving the bolt alittle will give u the needed clearance
    Sent from my DROID4 using Tapatalk
    *New for 2013: PWR Heads,GTP S3 Ported Manifold,90mm TB*,Tuned,Slammed (SOLD 6-14-13)
    Dec 2008
    Canton, GA
    Plenty of people have run 275-40-20s on the front. Maybe the alignment is off? I would recommend a 3mm spacer on the front.
    Nov 2009
    Thank uou guys for your. opinions . I would rather not use a spacer. if I can help it.
    perhaps I should go with staggered set-up. I can keep 275/40/20 in the back and use 255/45/20 in the front . Or should I go with 245/45/20 up front ? Does it really matter?
    Sep 2011
    South FL
    I'd go 255-45-20 all around.
    Lorain Oh
    Did it rub with the weight on the car or just in the air with the wheels hanging? And you didn't mention if these were on stock or aftermarket wheels.
    BFNY Performance
    440-787-7235 8am- 5pm
    BFNYPERFORMANCE@YAHOO.COM
    RIP NHDave
    RIP LOU1355
    Nov 2009
    THanks to everyone for opnions. INdeed it seems that 255/45/20 might be a way to go on all 4 corners.
    Quote Originally Posted by Hemi31 View Post
    The car was up with wheels hanging. My wheels are stock, came with the car and I got the car new. I am replacing the crappy GY RSA (245/45/20)
    Jun 2006
    between here and there
    do a staggered setup...245 or 255 in the front and the 275 in the back.
    2015 GCSRT8---stock for now
    2012 300SRT (SOLD) / 2009 MBP GCSRT8 (SOLD) / 2006 Brilliant Black Charger SRT (SOLD)
    Aug 2010
    Orlando Fl
    For those that have run 275/40/20's on all corners, I'm assuming you had same rim (width) on all corners? What was the rim width?
    Jul 2006
    Quinte West, Ontario, Canada
    Quote Originally Posted by Ironfelix View Post
    Hemi31's point was that once you put the car on the ground, the 275's will clear with OEM rims.
    2006 Charger R/T with Road & Track
    10.93 @ 125.6
    426 / Apache Heads / 239/247 Cam / Ported 6.1 Intake / 90mm TB / FTI 4400 TC / Getrag 3.23 / Tuned by JerseyBoy
    Dec 2009
    I would have tried to set car down on wheels, then it would have worked. Thats what happened when I put 275/40/20 on the front. The guy said it would rub, but after setting car down it worked fine.
    I live in a world all of my own
    Thats okay
    I know everyone there
    Best 1/4 12.891@107.64
    Nov 2009
    Quote Originally Posted by Adanac Charger View Post
    Yes, thank you...I kind of realized that too. I But, at the time I did not know. Anyway, we will have a round 2 at it in week. By that time I will decide if should go staggered or 275 on all corners. Thanks to all for the valued opinions.
    Sep 2011
    Manitoba
    I have a staggered setup of 275/40/20 in the rear and 255/45/20 in the front and even then I was told by the dealership that there was rubbing problems in the rear. That was only with the car on a hoist and when the suspension naturally pulls the wheels in. I told them that it would work and to just put the car on the ground and it worked fine. I am sure that this is probably the case with the front wheels. Make sure that you put the cars weight on the suspension and roll the car forward to make sure that the suspension doesn't straighten out the wheels so that the tires clear.
    Feb 2008
    Mechanicsville VA
    I have been running 275/40/20 vredesteins for several years and have even completed (27) total 30 minute track sessions on road racing courses........have not had a rubbing issue.
    Racing is like sex.........why would you want it to only last 10 seconds?????
    Road course session last 25-40 minutes each!!!!
