Results 1 to 12 of 12
    Jan 2010
    Jacksonville, NC
    Vortech V3 Maxxed Out Boost?
    I see alot of people saying they can't get their V3 past or up to 12 psi. But I have yet to see a 17% OD pulley, 28 tooth pulley, with the 2.62 pulley on the front. Has anyone tried this? I know the more you max out a head unit the less efficient it and you get more heat. I will be running an ice box so this won't matter. I'm just wondering what to expect.
    06 MSRT8: HHP Stage 2 Cam, SP Stage 2 Heads, 2800 Protorque Converter, Stage 2 Indy Ported Intake Manifold, Arrington 90mm Throttle body, Kooks Long Tube Headers, Custom Catback, AFE stage 2 CAI, Mopar TCM, BT Catch Can. SOLD
    Jan 2010
    Jacksonville, NC
    Jan 2008
    Jun 2006
    Lawton, OK
    This was discussed in this thread.
    http://www.lxforums.com/board/f288/v...0/#post4004134
    Inertia Motorsports Forged 345ci Block, High Flow Heads, Blower Cam, Procharger P1SC Supercharger, 3.4" Pulley, ATI 17% Overdrive Pulley, Mopar 65lb Injectors, 6.1L Ported/Heat Coated Intake Manifold, 90mm BBK Throttle Body, Mopar Headers, SLP LM II Cat-Back, Speedlogix Fuel Lines Front/Rear Crossover, Aeromotive Fuel Rails & FPR, Billet Fuel Hat with Dual 340 Pumps, Getrag 3.06 LSD with Upgraded Clutch Packs, SHR Transmission, ProTorque 3200 Stall Torque Converter, DSS 1000HP Driveshaft, DSS 1400HP Axles, Billet Tech Catch Can, Hotchkiss Sway Bars, KW Ver. 1 Coilovers.
    610 RWHP/547 RWTQ
    Jan 2010
    Jacksonville, NC
    Almost but not quite. I haven't seen or heard of anyone running the 2.62 front pulley. I will probably just have to do the R & D myself and see what happens. I hope the tranny can hold it together for a dyno pull.
    Jan 2010
    Jacksonville, NC
    Ok so I've used the impeller speed calculator provided by the vortech website and I found if using my a 7.07 or 17% od pulley with a 28 tooth cog pulley, and a 2.62 jackshaft front pulley at 6000 rpms the supercharger will be spinning at 66,800 rpms. The max is 52,000 rpms according to vortech. Thats way too much and boost isn't worth it if its not efficient. If I keep the 32 tooth cog pulley that I have now and change the front pulley to the 2.87 pulley I hit 52000 rpms at 5847.344 rpms. And yes I played with it until it was exactly 52000
    So I will purchase this pulley and pray for no slippage and see what happens.
    Oct 2010
    Alabama
    The 17% OD is larger than 7.07"
    Jan 2010
    Blue Springs MO
    Quote Originally Posted by PWR.Brittany View Post
    what is it as the website stated it was 7.53"
    PWR Prostreet 419 twin S300sx3-66 78/73mm Turbos,SHR Tranny,Protorque 4400,Super Dana 44,KWV2 suspension, Custom Fuel System W/Triple Walbros, ID2000's, Arrington 90mm TB Ported Intake W/Thermal Coating, Weld Racing Wheels 17x8 & 17x10, AMS 1000, BuilderBill TCM
    Jan 2010
    Jacksonville, NC
    Ok thanks for the correction guys I will play with the calculator some more.
    Jan 2010
    Jacksonville, NC
    With the adjusted OD pulley size the supercharger RPMs jump a little over 3000. At 6k rpms the 2.87 pulley hits 56,800 rpms, 4,800 over limitations. The next pulley is the 3.125 and at 6k the supercharger is spinning at 52,190 rpms. Thats dead on the max but I want to push the limits. Thoughts?
    Jan 2010
    Jacksonville, NC
    I was wrong on some calculations guys. The jackshaft cog pulley is 32 teeth and I was calculating for a 30 tooth. So I went with the 28 tooth supercharger pulley and left the front alone. RPMs at 6000 are going to be at 51,777 and at 6400 its 54,530. I asked Vortech if this would damage the S/C and they told me no. Placed it on order along with the tial 50 mm blow off valve and 80 lb injectors.
    Oct 2014
    Very old but what was achieved???
