Results 1 to 7 of 7
    Apr 2010
    Chicago
    changing brake fluid and trans fluid w turkey baster: what to get?
    Hello.
    Tomorrow I plan on replacing as much of the brake fluid as I can using the turkey baster method.
    While I know there is a writeup for power steering to replace all of it, I don't have a helper so I'll replace as much as I can with the baster.
    What type of fluids should I get?
    My 180* Tstat came in so I'll be replacing that tomorrow as well.
    Already have some distilled water for that.
    Feb 2005
    Near salt water
    Seeing as brake fluid is only as good as the bad stuff thats left over after the fluid change, I'd say replace it with the cheapest stuff you can find. There's literally no point in doing anything fancy. You'll be at the wet boiling point of the old fluid no matter what you do if you are just changing out of the reservoir (in fact to be honest I wouldn't bother).
    "LxF welcomes with open arms all members, regardless of social status, creed, color, sexual preference, or anything else. The only thing we discriminate against is douchebags."
    Check out Darth Hemi in the LxForums Garage
    Lorain Oh
    ^^^^^^x2......just do it right or don't do it.
    BFNY Performance
    440-787-7235 8am- 5pm
    BFNYPERFORMANCE@YAHOO.COM
    RIP NHDave
    RIP LOU1355
    Feb 2007
    L.A., Ca.
    Brake fluid and P/S fluid are probably the most neglected fluids.
    Remove the crap from the brake fluid reso, and then bleed the system, starting at the furthest wheel and working forward.
    the tranny will require a pan drop. Measure the fluid removed and replace with that amount.
    The TC holds quite a bit, so it can be changed several times to keep it clean.
    Adaptive Craving Control-by Hal9000 modification strictly prohibited
    FI IV.5, Solo cat backs, 180 thermo, Catch Can, DS tuner, 383 Stroker/SRT heads,headers and mids,, Tranny cooler with fan control, built tranny/flex plate/4K conv,09 Chally rear with Quaife posi. Pedders Track II, coil overs, Hodgkiss sways, BWoody links, 20" Jacks N Five with Nitto Invo's, Custom brakes by TCE. Bling by BT.
    Just a grocery getter!
    Tucson, AZ
    The turkey baster is just to get the reservoir empty so you can add fresh new fluid and begin the bleed process. Keep adding to the reservoir as you bleed each brake line. It's pretty easy to do. Make sure you have the right size clear vinyl hose and a container to hold the old fluid.
    Mar 2009
    Edmonds, WA
    Turkey baster is waste of time for brake fluid, the bad stuff is in the calipers and needs to be bled out with a vacuum tool while refilling resevoir. Besides, you don't want to dripping that stuff all around.
    I have done the power steering that way (I know pull line from cooler and pump out while refilling) but its easier and better than not doing anything! I tend to do the baster meathod on PS once a year.
    Sent from my SCH-I405 using Tapatalk
    Oct 2004
    LaFargeville, NY
    As ZMagnum pointed out, its good to clean out the res BEFORE starting to purge the system of the old! I alwasy suck out the tank and fill with fresh before starting on 6 month old fluid. At the track w/fresh, it is not needed to drain the tank, just fill and flush.
    05 Magnum RT 5.7 (Member ALLPAR.com 200,000 mile club) Rockinsrt8 shifter, Hemi reg #164 325,000 miles
    Sidewinder, 6.1 pushrods, springs, underdrive pulley, SRT exhaust (donated by NHDave) headers to tips, all installed by Hemi31! Quaife, certain Pedders bushes installed, SRT Nivomats and Bilsteins. Police rotors and pads. HIR. Predator. LMI.
    09 Jeep GC Limited, Hemi powered of course.
    1:19 NJMP Lightning
    1:45 Mosport
