Results 1 to 5 of 5
    Jul 2010
    corpus christi texas
    memory seats wont move back
    the "easy out" function for my seats doesn't work. i can push the buttons and the saved positions work, but they dont move all the way back when i take the key out anymore. is there a reset procedure for it.
    2007 300c srt-d. 5.7 180 t-stat, underdrive pulley, long tube headers, 3k stall, sidewinder cam, egr block off plate, sts kit currently at 5 psi
    Lost815's Avatar
    Lost815 is offline YEAH...I get all my Tattoos for free....
    Oct 2005
    In the driver's seat with the pedal to the metal!!! Socal transplant in Salem, OR
    There is a setting in the evic that will let you turn them off and on
    Apr 2010
    Chicago,IL
    Yes turn the car on,dont sit inside it,move the seat back all the way,than forward all the way,than back again..remove the key and close door.than open the door,sit inside the car start the car and the seat should go to its saved postion,if not press the memory buttom number and once its in the right postion turn the car off and the seat and steerimg wheel should both, move
    Sent from my DROID4 using Tapatalk
    *New for 2013: PWR Heads,GTP S3 Ported Manifold,90mm TB*,Tuned,Slammed (SOLD 6-14-13)
    Jul 2010
    How do I change it from there
    Jul 2010
    That did the trick, thanks guys
