Results 1 to 15 of 20
    Apr 2010
    I'm a Viking from Sweden
    Paint intake manifold
    I want to paint my manifold black, but I don't like the texture it has stock. Any advice on sanding it down? What paint to use?
    Thor From Sweden - SOLD
    There's no replacement for displacement. MEEP MEEP
    "Why are nordic people bat **** crazy??? Every car video from that part of the world is typically some older car, usually a Volvo, with enough power to bend space and time. They are up there with the Australians for the title of most rampant lunacy within an automotive crowd. I mean this with all due respect and admiration. It's just that I have a feeling that some dude in a viking hat is attempting to supercharge his SAAB with a hadron collider and will destroy the world by opening a black hole" // Ihazpower
    Jul 2009
    lancaster pa
    paint or powder coat?
    Apr 2010
    Which ever that gets the best result. I can paint myself, and I have a company who powder coated all my 3G customz parts for 80 bucks so they can do the manifold.
    Jul 2009
    lancaster pa
    First remove the coating thats on the manifold with a aircraft grade stripper then have fun sanding if your gonna powdercoat then you should only need to go down to a 80 grit as the powder will melt and fill the small crevices. good luck
    I always just use spray paint with some high heat primer.....works well for me, never cracks or looks bad! I spray painted my 20" clads and they held up pretty well! Look pretty damn good for 20.00 and a couple hours of time. I DD the car and it's been through rain, heat, cold and same paint has been on the wheels for 2 years now.
    first time out 11.28 @ 123.94MPH 1.89 60ft +3500DA R.I.P Kenne Bell
    Jul 2009
    lancaster pa
    The op wants it smooth
    Dec 2008
    Long Beach, CA
    Any advice on which grits to use?
    Feb 2011
    PALMDALE
    get yourself a dremel or a cheap one from harbor freight and and an orbital sander...makes quick work of large areas then use the dremel for the hard to reach spots and grooves...
    Jul 2009
    lancaster pa
    start with 20-36 grit and work your way up
    Bossier City, Louisiana
    I'm starting to think our cars might look pretty damn similar by the end of the year
    2006 Magnum SRT8
    D1 Procharged...
    Apr 2010
    Why is that?
    Black MSRT with Black Wheels, Procharger D1SC, 3g engine dress up, painted/powdercoated intake manifold, etc. It will all hopefully be done by the end of the year.
    Apr 2010
    Ah, yea. It will look pretty slick when it's done. Let's compare pictures later.
    I got the aac style halos, challenger wheels and nitrous - what do you have
    Mine looks basically stock with powdercoated wheels and tinted tails. Under the hood is just a frankentake with SLP LM2's.
    Feb 2007
    FT Bragg, NC
    I thik the Wrinkle Black will look good under the hood. Check out Legmakers, he originally had his manifold painted Black then went to the Wrinkle Black. I think the Wrinkle Black looks better. That's something that I'm looking at doing later this year.
