Page 1 of 4 123 ... LastLast
Results 1 to 15 of 47
    Apr 2010
    Chicago,IL
    Removed molding,now problem
    So I removed the side moldings on my 300 srt..removed all the glue and everything..drivers side looks really good,passanger side,well not so good.ib got keyed on that side 4 months ago and had a shop repair it so they had to blend the paint and did aq good job,but now u can see how it was painted between new and old paint..anyway to fix this without taking it back to the shop.i totally forgot about it
    Posted from my DROID!
    *New for 2013: PWR Heads,GTP S3 Ported Manifold,90mm TB*,Tuned,Slammed (SOLD 6-14-13)
    Sep 2010
    West Covina Cali
    Claybar?
    Oct 2009
    Sitting next to Harvey Dent. "Hi."
    Well at least you didn't have bubbles like I do.
    Apr 2010
    Chicago,IL
    I haven't tried anything yet..did it last night at work at 1am..
    Mar 2009
    Long Island NY
    Try to polish it out to smooth with PC polisher?
    2005 BRIGHT SILVER METALLIC MAGNUM R/T. MODS TO DATE:LMI CARBON FIBER HAMMER BLUE FILTER A LA CHRIS,BILLET TECH SATIN CATCH CAN. BLUE HOSES UNDER HOOD,DANKO LIP SPOILER FLAT BLACK,RED R/T ON GRILL AND REAR HATCH.BLACK BUMPER INSERTS AND BLACK SIDE MOULDING. VINYL DECALS MATTE BLACK HOOD STRIPES,TRUE SRT8 UPPER AND LOWER GRILL A LA DENNIS!!!!! RIP MAGNUM on 4/5/13. New ride 2015 challenger Srt392. All black emblems,hellcat airbox. 4/30/15
    Apr 2010
    Chicago,IL
    Quote Originally Posted by hot wagon View Post
    I don't have a pc polisher
    Nov 2007
    Valley Center, Ca.
    Nice Christmas present.
    Quote Originally Posted by Srt_Driver View Post
    Jul 2006
    California
    Can you take it back to the paint shop? If they were spraying up to the molding they should have removed it to do the job and then replaced it?
    Apr 2010
    Chicago,IL
    Quote Originally Posted by Quick View Post
    The scratch was from the mirror to about 5" above the side moldings..they ended up repairing it and painting the entire door,but not underneath the molding
    Dec 2010
    Boyle Heights (East Los Angeles)
    I think you should take it back to the shop. Doing the job right means taking the molding off, painting the door and replacing the molding.
    They should repaint the whole door for you.
    So Dark Even The Flames Are Black!
    Feb 2008
    Naperville, IL
    It makes me laugh when people recommend claybar to fix paint blemishs. It's a surface cleaner only.
    2006 black /SRT//8/
    Autocross videos - (((((SRT8 Charger autocross lap.))))) (((((Edited movie.))))) (((((Helmet cam lap.)))))
    Apr 2010
    Chicago,IL
    I'm assuming a high speed buffer with the right pad would do the job,but if I do pay for the service,will it actually fix it
    Jul 2006
    California
    Quote Originally Posted by Jontoad View Post
    Not even that so much since clay bar, used properly, never even touches the surface. It's purpose is to remove particles/shards/pieces of stuff that is "stuck" into the surface (and is now sticking out of the surface). The clay glides *above* the surface on a film of lubricant and snags particles sticking up out of the surface. Totally non-abrassive. Having said that, I believe there are some "clays" made and intended to be slightly abrassive? but that's sort of something altogether different.
    Calgary, Alberta
    Quote Originally Posted by Speed View Post
    ^x2...they did not do a proper job. No buffing will alter paint defects...
    Sep 2010
    in the snow,Canada
    3X
    That clearcoat line "could" be buffed/polished out but will always be a line.This is where it'll start peeling/lifting off.
    The only proper fix-repaint the whole door.Shouldn't be a big deal,wetsand and re clear.
    I drive a Hybrid.It burns gas and rubber
    07 300C SRT Inferno Red
    Comp 268 cam. Ported Mean Street heads.Pro Torque Billet TC 3000.Stainless Works long tubes.H/F cats,Flomasters,resonator delete.TranZformer.170 Stat.LMI CIA.DRL's are 6000K HID fogs.Demoulded,custom badgeing.BT catch can.Billet Grill.Red Brembo's.Diablotoona tuned.Bling by Kutz.
