Results 1 to 15 of 28
    Oct 2010
    Orlando
    6.4 Cam In 5.7??
    Can it be done?? Been looking on the forums with no definite answer.... seems there might be a piston to valve clearance issue since the 6.4 392 pistond have valve reliefs in them?
    Anyone know?
    Sold 2011 Hemi Express
    12.41 @ 110
    http://www.youtube.com/watch?v=BA_UAWbGYZE
    Modern Performance Engineering
    Jul 2007
    Outside Fargo, ND
    Why not go with an aftermarket cam?
    JBA shorties catless mids and SLP Loud Mouth I, K/N typhoon, powerbond undrive pulley, 170 tstat, mopar TCM, blue tops, R1 crossdrilled/slotted rotors, HAWK Pads, SRT MAX on 112, CNC Inertia Heads milled, 3000 Edge converter 3.91 Getrag 09 axles installed!#157 of 1400
    157 0f 1400
    http://s182.beta.photobucket.com/use...20563452620283
    Oct 2010
    Orlando
    stock 392 cam is only 60.00 from dealer
    Sep 2008
    Huntington Beach
    Yeah but I'm sure they designed that cam with VCT in mind. My guess is it would be a ton of low end but no top end, or vice versa, dog taking off then screaming up top
    Mod List in order of intstallation:
    window tint, magnaflow catback, airaid cai, srt shocks and springs, srt wheels, AAC interior LED Kit, 180 Tstat, predator 93 oct cai tune, srt sways, jba shorties, and sidewinder cam.
    316 HP/358 FT LBS *before cam*
    best 0-60: 5.58*before cam*
    338 HP/366 FT LBS *after cam*
    best 0-60: 5.33 *after cam*
    Oct 2010
    Orlando
    my motor has vct and so does the 392 cam
    Nov 2007
    Weston, fl
    Feb 2006
    N Misssisspi . Memphis TN
    cant tune it not going to work
    2012 Superbee SRT8
    11.928 @ 113.79 canned 93 tune corsa catback and dr's
    Jul 2010
    Central PA
    Quote Originally Posted by mexi View Post
    bingo!
    Oct 2010
    Orlando
    Ummm. I can. I have a working 2010 pcm in mine
    Dec 2008
    Larksville, PA
    You're factoring in a cam cost but by the time you throw in the required SRT springs, gaskets etc it's not worth throwing in a $60 cam with questionable gains IMO. Grab an aftermarket one used for like $250-300, the extra $ is well spent.
    Charlotte, NC
    Quote Originally Posted by Tomguy View Post
    I was told the same thing about running a 6.1 cam in my 5.7. I ran with or faster than the sidewinder cars I lined up against.
    I would check PTV clearance and also pick up an adjustable timing set just in case you need to dial the cam a few degrees.
    Does anyone have the specs for the 392 cam?
    The Old
    The New:
    Nov 2008
    Panama City, Florida
    Quote Originally Posted by Runner2go View Post
    bingo!
    Why can't you tune it....the 2011,2012 PCM haven't been broke yet, don't mean the cam with a older pcm can't be tuned
    The 5.7 with MDS .472 intake .460 exhaust.Duration is 258/288
    The 6.4 with MDS .577 intake .537 exhaust.Duration is286/288
    Hemi Registry #1348 SuperFrawgie 1361
    Feb 2006
    Quote Originally Posted by SuperFrawgie1361 View Post
    by his sig suggest he had a 2011 truck and 2011 pcm
    Dec 2009
    Park Hills, MO
    Quote Originally Posted by concussion View Post
    I agree with concussion. You seem to be the pathway for the 2011 5.7 crowd anyhow. I say give it a shot. If it wont clear ptv the you already have the motor striped, just get an aftermarket vct cam.
    I AM ON MIL DUTY PLEASE EMAIL SALES@EUROCHARGED.COM to contact about TCMs.
    2005 Silver Magnum R/T
    1/8 NA PB: 7.466@91.83mph 1.620 60'
    1/8 N2O PB: 6.947@96.50mph 1.539 60'
    1/4 N2O PB: 10.941@123.71mph 1.539 60'
    Oct 2010
    Orlando
    Ill still need to do springs if I do an aftermarket cam...
    plus the 392 cam is just as healthy if not more than most aftermarkets
