Results 1 to 5 of 5
Thread: Window Trim
    Medford, Long Island
    Window Trim
    How do you remove it? I drive an 05 Magnum. It's all faded and was thinking of plasti dipping it. Is it maining for looks or does it keep moisture/rain out? Thanks in advance.
    CURRENT MODS: AFE II Intake-PWR Heads and Cam-SLP Long Tubes-SLP UD Pulley-Borla 125s-Eagle Intake-NGK V Power Plugs-Moder Muscle Throttle Body-Mopower Chin Spoiler -BT Oil Catch Can-Innovate Wideband-Eibach Dampers-Hotchkis Sway Bars and Lowering Springs-SRT 8 Gears, Mopar TCM-Edge Racing Converter-TransZformer Shift Kit-Lows/Fogs HIDs
    Indiana
    I think there is a way to get to screws to release it on the side of the door otherwise you need to remove door panel. I know I saw a thread talking about removing these somewhere on here but can't remember where
    Aug 2010
    Dyess AFB, TX
    Quote Originally Posted by Bigdirtyd View Post
    what he said, you have to take off the door panels. I did that to mines when I had my maggie. It was a PAIN in the ass to do!!
    I HIGHLY SUGGEST JUST TAPEING EVERYTHING OFF!!!
    Robert
    2006 300C SRT8
    Predator 91 oct Tune w/ CAI, Zoomers Exhaust, LMI "Frankentake" CAI, 6000K HIDs, Staggered Avant Garde Wheels F420, Bagged with Uiversal and BC coilovers, TruFibert Chally Hood, and BT BLING!
    Oct 2010
    Orlando, Fl
    Yep. I have a thread on here with instructions to remove them. The rears are where you need to remove the door panel. The fronts you can get off without doing so. There is a torx screw on each end of the molding holding it on then you just carefully slide them up. They do keep moisture out of your doors so they're there fo a reason.
    http://www.lxforums.com/board/f57/wt...ldings-267661/
    Just make sure you take the rear door panels off other wise you end up bending & pretty much breaking the molding to get it off
    LMI True 4" CAI - Tranzformer V2
    Killer Glass - BT Catch Can
    Doing some reading, I like the color matched moulding. Can I get spray paint for the plastic trim or will it just come off? I have an inferno red magnum.
