Results 1 to 5 of 5
    Feb 2011
    Vacaville, CA
    Cut/remove engine cover mounts/fuel rail screws??
    Has anyone cut these down? Replaced with a flush mount screw? Is there an OEM part number that replaces these? I dont ever plan on running a cover again and trying to clean up the bay. When I get new fuel rails, will it come with new hardware? They are such an eye sore!
    Aug 2009
    Silver Spring, MD
    just go to a hardware store and get a nice set of cap screws
    Feb 2011
    Vacaville, CA
    I'll def look into those. Thanks!!
    Dec 2006
    SAN DIEGO, CA
    You can tap the 5.7 manifold and use a 6mm bolt. Who's fuel rails are you using?
    Feb 2011
    Vacaville, CA
    OEM rails right now but am looking at a set of BBK's or Aeromotive. Not sure if either comes with new hardware.
