Results 1 to 7 of 7
    Sep 2010
    County Durham,United Kingdom
    Question Tacho signal from alternative source
    Can automatic transmission input speed sensor on a electronicly
    controlled transmission be used for tachometer/rev-counter signal?
    The reason I ask is on my engine swap the doner car's gauges all
    went on a bus system and not separate wires.
    The car the engine is going into has the wiring for separate gauges.
    The speed sensor is coming off a sensor on the adapter part for the
    transmission an will give the correct speed of the car.
    But the rev-counter signal where to connect to get a good correct
    signal! Someone suggested tapping into the input speed sensor on the
    transmission.
    The doner Vehicle was a 1998 Chrysler Voyager/Dodge Caravan v6 engine
    and a 4 speed automatic transmission (41te)
    Any help or suggestions welcome, and thank you in advance.
    I'm diabetic,I'm disabled BUT I'm not dead yet!!!
    The ONLY Right Hand Drive Neon with 3.3L v6 Engine & 41TE ATX SWAP
    Sep 2010
    There are a few different web sites with DIY versions oF the tach adapter.
    Tachometer Installation
    http://vstar1300.pbworks.com/f/TachAdapter.pdf
    I have found after a little research a cheap tach adapter $10 plus postage.
    This small board adapts a Tachometer to up to 4 individual coil packs, capable
    of handling 4, 6 or 8 cylinder wasted spark applications
    Installation is straightforward:
    * Connect Coil 1,2,3 and 4 to the drive signals to each coil packs as necessary.
    * Connect the tach output to the input of your tachometer.
    * Wrap the board with electrical tape or shrink tubing- the board is small enough
    to integrate into your wire harness / bundle.
    Example Wiring
    Here is the the web address
    TachAdapter - Autosport Labs
    I have purchased one from their website with paypal.
    So I will try it when it gets here in about 2 weeks time.
    This could be used on other vehicles for engine swaps etc.
    Sep 2010
    Okay as there was no real scale to the photo with the tach adapter.
    And that is 15/16 of an inch.
    please look at my engine swap to see it get wired up.
    http://www.lxforums.com/board/f64/re...ml#post3863039
    Apr 2006
    you are trying to attach a tachometer for engine rpm?
    typically you tap into an ignition coil for that I believe.
    I'm only responsible for what I say, not for what you fail to understand.
    Jul 2008
    Hughesville, MD
    Quote Originally Posted by Mr. iNCREDIBLE View Post
    tap into a coil or injector is what Ive always done
    CAM ONLY RECORD HOLDER 12.34 @108.89 & 1.66 60'
    Email mailed tuned by Brent@dtpracing.comComp268cam,
    Apr 2006
    Quote Originally Posted by moparmike610 View Post
    me too, and transmission tail shaft for speedo, or now you can get a get speedo gears for older (pre 1980 usually) transmissions that convert the speedo gear output to electronic as opposed to a cable setup.
    Sep 2010
    With the above adapter it takes the signal to the ignition coils and turns it into a true rpm signal.
    Coil packs are one coil for every 2 cylinders usually, so only tapping into one coul means you're
    tach will be only showing a third of the true rpm.
    As I have plenty of used insulin pens, and the cap/cover is
    the right size I decided to use a bust one as a holder and
    protector for the tach adapter.
    I show an undamaged insulin pen next to the cap and
    snapped off end how it will go together.
    (the insulin cartridge was undamaged)
    Almost done the below picture is before I used gasket
    seal to glue and seal the bits together.
