Results 1 to 15 of 21
    Feb 2010
    Track time 2012 R/T
    Feb 2010
    Arizona
    i dig the short gears in the 6 speeds, didn't realize they were that short.
    Did your woman make it home with you after she laughed
    Feb 2010
    Quote Originally Posted by Wardo View Post
    That was my daughter laughing because she was bouncing the phone (video) around on the shifts. I don't own any Mopars I own GM stuff, this Challenger is a great car and fun to race and cruise. Just thought I would post up for the forum.
    near springfield missouri
    wow only 13.9.???
    [SIGPIC][/SIGPIC]
    6.08 l magnum R/T
    371 PWR stroker, 13.8.1 compression, E85,Thitek Heads.
    My new build!!! Thanks to Kent Irwin
    http://www.pwrparts.com/
    Tuning By Mike at
    http://www.ostdyno.com/
    Feb 2010
    Quote Originally Posted by 05silvhemimag View Post
    wow only 13.9.???
    Yup, car falls real flat in high gear and 60 was 2.15 on a good pass. Car has 300 miles and stock.
    Nov 2008
    Concrete Rage, NY
    wow only 13.9.???
    That's about normal for an R/T. Mine went 14.002 stock on street tires. Plus, the O/P didn't put where he's from, so maybe his DA was really high....
    BTW...welcome to the forums
    ​GALVATRON
    2010 TorqStorm Supercharged plum crazy Challenger R/T on 22" VOSSEN CV3 wheels!!
    Current 1/4 mile (before supercharger): 12.965@105.61mph bangin' 'n clangin'!!!
    Speedlogix
    Northeast Rep + Internet Sales Evangelist
    Modern Mopar Magazine
    Writer/Contributor
    Feb 2010
    Quote Originally Posted by Galvatron View Post
    Thanks, I come here from time to time to read up. Im sea level. Its my dads car and hes going to do a programer and cold air, should run 13.5 or better through the cool months here in FL. Good times for sure! Im die hard GM but love the Challenger for sure.
    Mar 2011
    Spring, Tx
    Prior six speeds have torque management applied on every shift,pulls timimg to save wear and tear on the the transmission.No, you can't tune it off with the predator.The high rear end ratio forces you to shift one extra time.The predator tune reduced my 1/8th mile time by .6, other mods have it down another .5, Looking for another .1 tomorrow as expected temps will be in the 50-60's.Yesterday in 59*, DA of -207,I ran a 5.1 0-60,.4 better than my previous best and that was letting it spin like crazy,didn't even try my normal launch routine of brake torquinng at 1200 rpm which consistantly gets me 2.0 60s at the track. http://www.lxforums.com/board/f350/s...57/index3.html Go to post 37 shows severe retarding of timng on each shift. I chose an auto for different reasons.I have chronic bursitis in my right shoulder and have had two surgeries on my left knee.Not conducive to power shifting a stick.Bought a 2010 because I couldn't find a 2011 last Feb.Pure luck that I ended up with a 2010 that could use the predator. The $5000 discount was nice too.
    K&N drop in, suitcase delete with two magnaflows,resonator delete,180 stat,Predator 93cai tune, clean air duct, fastman TB,srt8 suspension upgrade.hood struts.Best 1/8th mile1.99 60ft., 8.51@83.97 mph DA 795. Dyno 334 rwhp 359 ft lbs temp was 102.18*, DA 2650 ​Best 1/4 mi 2.11 60 ft. 1/8th 8.71@82.77 1/4mile 13.41@105.49 DA -88
    Jul 2007
    Albuquerque, NM
    Great video, really feels like I am driving It sure does lay down on you in 4th gear, still though, I bet you could trim your time by a couple tenths stock.
    '12 Challenger SRT8 Pitch Black 6-speed, stripe delete, all options
    -AFR functional SHAKER hood, Hurst/Mopar short throw pistol grip W/Larry's mod, BB's resonater delete, Jet 180 t-stat, HEMIFEVER tune, BT catch can, ceramic tint/clear bra/C-Quartz...you know, some other crap too
    13.56@104.38 stock tune/tires DA 7170 - that's 12.33@114.45 corrected!!!
    Phoenix, AZ
    I'm sure the car has more in it than that. Given some more miles, and a few more times at the track, you'll probably get better times.
    Surely a 6 speed, with more power and a little less weight is more than 2/10th's quicker than my stock Magnum.
    2006 Dodge Magnum R/T - SC Flashpaq, Volant exhaust, 22x9.5" Boss 338, 265/35/22, 14.1@98MPH
    2000 Jeep Wrangler
    1966 Dodge Monaco 500
    http://www.cardomain.com/ride/3250470
    Mar 2011
    Spring, Tx
    A 180 stat will help.Don't run your AC they frown on that, but turn on your front defroster,the fan will run and you'll run 20 degrees cooler.I do it while I'm in the staging lanes even with the predator you can heat soakAlso after I clear tech, I park it and raise the hood,for 20-30 minutes.It's like a blast furnace under there.I figured that out when all my 1st passes were my slowest.Not anymore...
    Feb 2010
    Yes, I was dissapointed in myself I couldn't get a 2.0 60', I will get it next time out. How good are the factory clutches?
    Apr 2011
    Rochester Hills, Michigan
    LC
    I will break in a little. I just ran a 13.59 @ 102.4 with 2.013 60' with DA at about 1000' . That's in a 2011 RT with an Automatic. Unfortunately there are no tuners for the 2011 do to a hard to crack roling code. I would love to add a 180 stat but without a programmer to adjust the fan turn on points lower I don't think it will do a ton.
    2011 Challenger RT+ with MOPAR exterior kit, MOPAR Cold Air Induction System, MOPAR T/A hood Ducting Kit, MOPAR "T" Handle Shifter, MOPAR Cat Back Exhaust System, Boss 338 Wheels, Drake Fuel Door, Billet Technologies fuel door badge & Catch can, Web Electric tail light sequencers....1 of 16
    PB: 13.125 @ 106.1MPH 1.937 60ft on Stock 245/45-20 4 season street tires
    Hemi-Registry #1637-scottymac
    Feb 2010
    My dad said he was looking into supercharger/procharger kits and I told him the tune was going to be an issue for a while. I guess he is looking at one for his Camaro now because of the tuning issues.
    Mar 2011
    I had a chance to take out a 2011 RT classic with the 6 speed last night (thinking about trading maggie in) and even the girlfriend commented after giving it a full throttle blast through the first 4 gears that the car didn't have nearly the power that my almost stock 5.7 magnum RT has, (I'm running a CAI and a borla cat back with a mild tune) the car seamed to have no torque at all.... it was still cool as hell to drive though! I WANT ONE BAD!! lol
    Current Ride... 2011 Challenger RT Classic White with black stripes and heritage wheels, Auto.
    2011 Challenger R/T Classic
    Tungsten metallic with Red Stripes and a 6 speed.....Status = dropped valve and destroyed engine April 2013, got back from dealer mid July 2013, so many damages done by service department over the 3 + months that I had to dump it
    2005 Magnum R/T Borla cat back 140125 (aggressive) K&N CAI, Dropped 2"s in all 4 corners SOLD
    1967 Belvedere II 440 auto, 299 hp/454 ft/lbs on chassis dyno
    1949 Plymouth business coupe 354 hemi
