Results 1 to 4 of 4
    Jan 2008
    Virginia Beach, VA
    Advanced search...
    I am trying to do an advanced search and keep getting this...
    "The following words are either very common, too long, or too short and were not included in your search: e85"
    Any suggestions?
    Gunner (Mike)
    2007 Tor-Red MSRT W/ SRT group I, II & III
    LMI true CAI, MMPG 87mm TB, GTP Ported Intake Manifold, Inertia Performance Heads, FRI Tomahawk, 176* T-Stat, SLP U/D pulley, JBA Long Tubes with catted mids, Custom cat-back W/ Blastin' Bob's, PT 2800, Blue tops, Getrag W/ 3.73s and CMR tuned by Brent at DTP.
    11/11/11 11.504 @ 118.00, 1.598 60' W/ 315/35/17 NT05R DRs @ 20lbs, 93 oct pump gas, 4125lbs, and a DA of -680
    Apr 2006
    the forum search requires 4 or more letters with some minor programmed exceptions..
    the google search (upper right under your username) is less quirky..
    here is an e85 search:
    http://www.lxforums.com/board/result...ORID%3A11#1339
    I'm only responsible for what I say, not for what you fail to understand.
    Nov 2010
    Add in an asterisk. Really. Search "e85*" instead. Problem solved!
    http://www.lxforums.com/board/search...rchid=11843745
    Jan 2008
    Virginia Beach, VA
    Bingo! Thanks, I forgot about the "wildcard"
