Results 1 to 6 of 6
Thread: Clear on rims
    Apr 2010
    Chicago,IL
    Clear on rims
    So I painted my rims black about 2 months ago.they are still holding up nice with no chips or cracks...I didn't clear coat them at the time because it was to humid outside and I did try to clear on rim and it was starting to turn white'ish instead of a glossy black..now the humidy is under 50% and its a nice 60 degrees outside..would clear coating the rim now make it look glossy?I'm using the duplicolor rim paint,and duplicolor clear coat
    Sent from my Droid!
    *New for 2013: PWR Heads,GTP S3 Ported Manifold,90mm TB*,Tuned,Slammed (SOLD 6-14-13)
    Sep 2009
    Windsor, Ont
    I've found the Duplicolor clear spray sucks. I have wrecked so many parts using it with bubbles and it turning milky right out of the can. And that was in all different temps and humidity levels.
    May 2010
    Saskatoon, Sask.
    Quote Originally Posted by scotto View Post
    I have had it turn milky when first sprayed on but it dries clear
    2008 Dodge Magnum SXT AWD - Daily Driver
    2005 Dodge Magnum R/T AWD - Weekend Toy
    2008 Dodge Magnum SXT - Project car
    Performance mods: Edge 3000 Stall, Trinity, SLP LM2, Custom Dual CAI, BCRacing Coilovers, R1 Concepts brakes, Tranzformer, HemiTuner TCM, Paramount Stage 2 Valve Body, American Racing 20x8.5 Rims
    Other: SRT Fascia, Road and Track Seats
    60' - 1.95
    1/4 - 13.97 @ 99.7MPH
    Apr 2010
    Chicago,IL
    I defently don't want it milky..anyone recommend anything good that's works
    Sent from my Droid!
    May 2010
    Saskatoon, Sask.
    Make sure you do NOT mix brands of paint. Since you used dupi-color paint, make sure you stick with dupli-color clear. Mixing brands of paint can cause huge headaches with it not sticking (I sprayed dupli-color over armor-coat primer and the dupli-color just flaked off, even though it was applied the same as all the other things I have painted with all dupli-color with no issues.
    May 2009
    I would recomend spray max 2 part clear in a spray can SprayMax 2K Urethane Aerosol Clear Coat
