Results 1 to 15 of 22
    Chicago, Illinois
    Talking One-off PWR engine build....
    Here's what Andy posted on one of the other modern mopar sites...
    Some of you already know that the 6.1 block has a bore size of 4.055" and cant really go any larger than 4.08" due to cylinder wall thickness. I purchased 5 blocks at an auction a couple years back and this one block stood out as being different. The part number is different, the color is different, the water jackets are actually from a 5.7, but it had 6.1 cast into the side of the block. I sonic tested the block and found that this block could go all the way up to a 4.185" bore and still be considered safe. This was very strange to me so I inquired with a couple of guys in the know about what I had and this was their response.
    If that is the block I think it is, it used to be painted black. Of the 6 or so that were made, most were a rough 5.7L bore size with all other features finish-machined to the 6.1L print. Blocks were cast with the 5.7L bores but I thought we stayed with the 6.1L water jacket core and block material. Cam tunnel cores were 6.1L as I recall but we simply deleted the piston jet machining. Also, it seems to me our intent was to put a P at the beginning of the casting number, but I may be confusing that with the aluminum block.
    Anyway, if this is the block I think it is, it was an early attempt at a heavy duty/race/blower capable block for Mopar with the idea that we might be able to use it in a skunkworx supercharged buzz model. Never went anywhere and they kinda fell off the table when the discussion turned toward the 6.4L variant being conceptualized.
    So basically I have come across a 1 of 6 block that is capable of way more than any production 6.1 block out there. We have decided to use a 4.145" bore with a 4.08" stroke to build a 440 that will be able to handle over 1000hp and thats where we sit. Here is a pic of the block.
    Current - 2015 Chrysler 300S V6 rwd - Bright White
    Current - 2005 Dodge Magnum R/T - '15 Sublime/'05 Brilliant Black
    Current - 2006 Dodge Magnum R/T - Cool Vanilla - parts car
    Current - 2012 Dodge Journey SXT V6 - Pearl White
    Gone - 2011 Ford 'Whorus' Taurus Limited - daily driver
    RIP - 2005 Dodge 'Dirty Whore' Magnum R/T (12/7/11)
    Nov 2007
    Valley Center, Ca.
    That is destiny.
    Jan 2008
    Virginia Beach, VA
    Soo... a 440 capable of handling massive boost?
    Gunner (Mike)
    2007 Tor-Red MSRT W/ SRT group I, II & III
    LMI true CAI, MMPG 87mm TB, GTP Ported Intake Manifold, Inertia Performance Heads, FRI Tomahawk, 176* T-Stat, SLP U/D pulley, JBA Long Tubes with catted mids, Custom cat-back W/ Blastin' Bob's, PT 2800, Blue tops, Getrag W/ 3.73s and CMR tuned by Brent at DTP.
    11/11/11 11.504 @ 118.00, 1.598 60' W/ 315/35/17 NT05R DRs @ 20lbs, 93 oct pump gas, 4125lbs, and a DA of -680
    Bolivar, MO
    Does the motor already have a home or will it be up for sale?
    Billy Briggs 392 stroker with a 2.9L Whipple SC - Fore Fuel System - BB 8.8 rear end with 3.23 gears - CF DS - Level 5 Axles - Built Transmission by Enhanced Transmission - 90mmTB - Hemituner TCM and Tune - Installed by Erik at BFNY Performance - Bogart rims for the track - Leg maker CAI
    Jan 2008
    Nashville, TN
    Where does one go about finding these so called "auctions"?
    '06 Silver R/T with Road and Track on UAS
    Chicago, Illinois
    Quote Originally Posted by I fly 2 View Post
    it has a home in a pwr maggie srt
    Sep 2009
    Isn't that interesting
    Aug 2007
    JAMES ISLAND S.C.
    So that's the one!! I want to know where the other 5 are.
    PWR 426, Paramount Tranny/4000 dominator, PWR cam 247/252 115+2LSA, Apache Heads,
    Modern Muscle ported intake/90mm TB, Kooks LT headers, Billy Boat exhaust. LMI Intake
    Installed with love by AMP!!!
    flem's Avatar
    flem is offline Rain rain go away come again another day
    May 2010
    Skiing the East.
    I like "bastard block" written in the valley. Lol
    Modern Muscle (VA), Inertia, Arrington, LMI
    Dec 2005
    Arizona
    Wow, that is pretty dang cool.
    Apr 2006
    Huntersville, NC
    Quote Originally Posted by JimIsland-SRT8 View Post
    I know where some of them are
    Stock 5.7
    Aug 2007
    JAMES ISLAND S.C.
    Quote Originally Posted by MadCharger View Post
    Do tell!!
    Dec 2008
    Albany NY
    Liar.
    InferAl's Avatar
    InferAl is offline "R.I.P. Lou1355 "The Hellbitch lives On"
    NE Ohio
    Does that say what I think it says LOL
    2009 B5 Blue Challenger R/T /Billy Briggs 426/ Thitek Heads & Cam /
    Installed By BFNY Performance/
    SHR Trans Paramount 8.8 & Dominator TC /Tuned By Jerseyboy /
    Atco
    Video
    Ft Laud.....
    Quote Originally Posted by flem View Post
    Quote Originally Posted by InferAl View Post
