Results 1 to 14 of 14
    Jul 2010
    Napa, CA
    Mopar cold air Intake replacement filter?
    I have a Mopar cold air intake for the 6.1 and it has a dry element. is there a way to clean these? or is it better to just replace them with a cleanable type? any opinions on which one to replace it with would be nice.
    thanks guys
    Jan 2006
    Kingsport, TN
    You can purchase a cleaning/oiling kit from your dealer or any Mopar parts dealer who is a vendor here...runs about $16-$20......your filter should last the life of your car if maintained...
    PB 11.417 @ 121.56 ......
    2013 CHALLENGER SRT8 AUTO IN BLACK * LMI TRUE CAI * ARRINGTON STAGE II ALUM INTAKE* KW COIL OVERS * CORSA EXTREME CATBACK * MAGNAFLOW HIGH FLOW CATS * 3.73 GETRAG LSD * PARAMOUNT DOMINATOR 4400 STALL CONVERTER * SPEEDLOGIX LIGHTWEIGHT FACIA & REAR MOUNT * ARRINGTON 6.4 BASED 426 STROKER * 552 RWHP / 547 RWTQ * API 88MM THROTTLE BODY * COMP VVT CAM CUSTOM GRIND FOR ARRINGTON * DSS CARBON FIBER DRIVE SHAFT * DSS 1400HP HALF SHAFTS * TUNED BY THE HEMITUNER......MORE TO COME....
    Jan 2007
    Mopar Super Center. I just bought a whole new filter for like 40 bucks.
    Jan 2007
    Denver, CO
    F.A.Q.
    OR just use soap and water like I did.
    2006 Charger SRT8
    Mods: Magnacharger w/Toona Tune
    Forged 20" BC Racing wheels, Hotchkis sways
    Michelin Pilot SuperSports 295/35 rear, 255/40 front
    Pedders Street II suspension, Roto-Fab CAI
    Razors Edge front and rear strut tower braces
    Diablo Trinity, TranZformer
    Arrington air/oil separator / Billet Tech catch can
    Complete BT under hood bits w/BT valve covers
    Jan 2006
    Kingsport, TN
    Quote Originally Posted by raffin View Post
    F.A.Q.
    The filter requires special oil to work properly unless you have a dry filter like the AEM drylock.....the Mopar filter requires oil..
    Oct 2008
    Maysville KY
    He said he's got the dry element I think. Use soap and water then throw it away and go grab a cheap Spectre filter at Autozone. You'll be amazed how much better your car can breadth.
    Gettin' Lucky in Kentucky...
    Maysville, KY
    Jan 2007
    Denver, CO
    Quote Originally Posted by TNCHARGER View Post
    The newer Mopar CAIs come with the dry filter.
    Jul 2010
    Napa, CA
    Yes i do have the Dry element, I'll try to the soap and water, anyone know of a better filter to slap on there that would maybe work a little better? this one seems like it clogged up rather quickly, although i guess 20,000 miles of commuting i should expect that?
    Jan 2006
    Kingsport, TN
    MY bad there...been 6 years since I bought one.....
    Jan 2007
    Denver, CO
    I only know because when I was replacing my Mopar CAI filter I ran across that little tidbit. I bought the dry filter because it was easier to clean. Never noticed it being restrictive at all.
    Oct 2008
    Maysville KY
    Just go to Autozone and get a $20 Spectre blue filter. Fits perfect and is oilable and cleanable. I swear your car will breath so much better. Mine did.
    Mar 2011
    Spanaway, WA
    I had a dry filter CAI on my 05 Ram and washed it in the kitchen sink with the cleaning stuff from a K&N filter oiling kit. Washed it, let it dry fully, reinstalled without oiling, worked fine.
    Good info on the Spectre filter... I have the Mopar CAI also and might go that route when the time comes.
    SRT Max cam, SLP 25% UD Pulley, Jet 180 T-Stat, Solo X-3 catback, Roto-Fab CAI, and Zeitronix ZT-2 AFR, Blue Top solenoids.
    Cam install and tune by Troy Ding
    . Dyno 31Aug2012: 414hp/410tq _Idle Video_ Best 1/4 mile: 12.428 @ 110.94 mph
    All Mods listed at --> 6.1L Hemi Registry #1530 10ChallSRT8
    Jan 2007
    The filter from moparsupercenter is a direct replacement. says mopar and i believe its oiled.
    Jul 2010
    Napa, CA
    thanks for the info guys
