Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    May 2010
    NJ
    PCV under the boost issue ...
    when i do wot under the boost ( 9 psi ) i got this issue
    I'm tired from this **** please someone help me
    thanks
    Charger srt8 6.1lL , afe CAI, tune
    Aug 2009
    Silver Spring, MD
    Dec 2006
    SAN DIEGO, CA
    unless your pvc valve does not have a check ball it not your problem.
    Jan 2007
    Jan 2007
    And by the way, tossing a breather on each valve cover will help out greatly. You can use a regular breather, or weld some bungs up and run them both to a catch can.
    Edit: Another alternative is what I will be having fabbed up in the future. I will run two valve covers breathers to it as well as my crankcase vent line.
    orlando, fl
    clean out pcv. also might want to look into running a catch can off that fitting.
    ‚Äčwww.legmakerintakes.com
    9.44 @ 148 mph P
    WR forged 6.1 Procharger F1A Nitrous Outlet
    AfterHours Mopar Perf. installed!!!
    "This is what I love about drag racing. I feel an intense focus as everything is extremely loud and quiet around me simultaneously. Nothing else besides me and my immediate environment exists for these short moments." - Budoboy
    Aug 2005
    Pompano Beach, Florida
    Just my sillyness... Shouldnt these systems come with a solution for this??
    Hemi Registry 0436 PWR Forged 6.1 block -YSI @20psi -Modern Muscle Performance Stage3+ manifold and custom cam - 90mmTB- Indy Heads - TTI Longtubes - Enhanced(hemi31) TC/Transmission - HemiTuner TCM - BFNY 3.06 Getrag-325/45/17M&H 9.937 @ 138
    Oct 2009
    S. FL
    That's a lot of blowby.
    Especially to make a mess like that.
    May 2010
    NJ
    man that catch can look great for this mess
    I'm thinking to close the hole in manifold that draw to PCV and i will replace the PCV with fitting that draw to the catch can with breather
    after this day no need for PCV
    Feb 2009
    Central IL.
    Both mine go to catchcans, one with a breather
    2008 JEEP SRT-8
    CORDOVA DRAGWAY PARK
    10.91 @ 124.30 60' 1.499
    The "Elephant"/426ci/Whipple 2.4L (11 psi)/H2O-Methanol/Kooks LT/Corsa/PP Trans-TC/2800 Stall/FORD 9"-Wavetrac LSD/NT05R/6-pt. Rollbar
    Aug 2007
    Cypress, Texas
    Quote Originally Posted by jdoc7 View Post
    would you have pics of your solution? Having difficulty visualizing the setup.
    2007 Dodge Charger SRT aka Black Widow
    2009 Dodge Challenger SRT aka Sinister
    Arrington forged 392\ProCharger D1SC (11.20/124mph)
    Aug 2009
    Silver Spring, MD
    Quote Originally Posted by DarthCharger View Post
    instead of a filter going on the oil fill, you put a catchcan on it. the link i posted in the 1st reply is a basic one
    May 2010
    NJ
    hope this solution will help
    any suggests ?
    Jul 2006
    Put a second straight through pcv valve in the line between manifold and stock pcv. Throw that filter away, attach a catch can off the vent line fitting, and attach other line off catch can somewhere between air filter and compressor inlet so you are always pulling vacuum through catch can. In 5 years have never blown oil like that.
    North Coast Turbo Systems LLC
    Home of the fastest 5.7 Cherokee, 13.39@104.62 MPH
    All stock internals 5.7 Hemi with a bolt on turbo, Tuned via the iEMS3
    Sharadon Performance Valve Body
    May 2010
    NJ
    this drawing show u what i will do with this issue
    2 catch can one of them with breather
